975804 Posts in 138943 Topics by 6363 Members - Latest Member: V6 DOW November 23, 2024, 04:39 AM
RADBMX.CO.UK  |  Mid School BMX (>87) 1989 to 2003 (<05)  |  Mid School ( Keep the faith )  |  1991 Haro Edge
Author Topic: 1991 Haro Edge  (Read 36608 times)
Offline sparkysx
1991 Haro Edge
« on: April 19, 2012, 08:44 PM »
Finally got my hands on one, thanks to ED209º and khebeater telling me that there was one on ebay.
Paid £50 for it, I was the only bidder, if there was no nostalgia attached then it wouldn't of been worth it.
First picture below, this is how I received it.
Came with a Haro labeled Dominator, which is nice.
Going to try and keep it original, so if anyone has good condition parts that I will need or knows of them, LMK  :daumenhoch:
« Last Edit: February 09, 2013, 08:37 PM by sparkysx »
Re: 1991 Haro Edge
« Reply #1 on: April 19, 2012, 08:57 PM »
£50 .. thats a result that! should be sweet when its done - well done on getting one at last  :daumenhoch:
Offline sparkysx
Re: 1991 Haro Edge
« Reply #2 on: April 19, 2012, 09:13 PM »
Yeah couldn't go wrong really, a repop Dominator would cost £30 on it's own anyway. The rails are covered in a light coating of surface rust, maybe wet and dry those in place, as I have read that once you take those off they don't go back on again.
The seatpost was rusted in place, which I think is why the seller wouldn't answer my questions about whether the bike would be dismantled for shipping, they couldn't dismantle it! 'm different though, I got the seatpost off without too much trouble!
Thanks again Ed, first one on the bay for 6 months or more.
Online mattfx81
Re: 1991 Haro Edge
« Reply #3 on: April 19, 2012, 09:21 PM »
There are loads of mid school haro parts on the bay, I cant see it being hard sourcing parts for it. Good luck with the build.
Offline Hmoon27
Re: 1991 Haro Edge
« Reply #4 on: April 19, 2012, 09:31 PM »
Was gonna have a go on this myself, nice score fella :daumenhoch:
Offline sparkysx
Re: 1991 Haro Edge
« Reply #5 on: April 19, 2012, 10:32 PM »
I'm glad you didn't or it would have pushed my max bid up, which was a fair bit higher than £50!
Offline sparkysx
Re: 1991 Haro Edge
« Reply #6 on: April 20, 2012, 12:21 AM »
Looks like this ebayer is going to earn their first bit of negative feedback, the forks have been cut and there was no mention of this in the auction. I assume this means they are knackered?
Offline sparkysx
Re: 1991 Haro Edge
« Reply #7 on: April 20, 2012, 12:22 AM »
Thats the maximum they show above the frame.
There is 32mm of thread left.
Offline sparkysx
Re: 1991 Haro Edge
« Reply #8 on: April 20, 2012, 12:53 AM »
I assume I can't run a gyro with this pathetic amount of thread?
I've asked them for an explanation!
Mdbh
Re: 1991 Haro Edge
« Reply #9 on: April 20, 2012, 09:58 AM »
You might just! You need to find a really thin middle nut, and run no washers? But not sure
Offline sparkysx
Re: 1991 Haro Edge
« Reply #10 on: April 20, 2012, 10:10 AM »
Can i buy more 1" forks and weld the thread to the top of these? This steerer is 7" long fron very bottom to top
Mdbh
Re: 1991 Haro Edge
« Reply #11 on: April 20, 2012, 10:16 AM »
Yes that is possible if your handy with a welder give it ago!
Offline sparkysx
Re: 1991 Haro Edge
« Reply #12 on: April 20, 2012, 10:46 AM »
Depends on whether it can be mig welded or nor
Offline Dannywhac
  • return of the whac
Re: 1991 Haro Edge
« Reply #13 on: April 20, 2012, 11:00 AM »
I'd just go with levelling off the threads, and like Olly said use the gyro but don't use the headset washer (or use a real thin one) :)
Offline sparkysx
Re: 1991 Haro Edge
« Reply #14 on: April 20, 2012, 11:25 AM »
So cut the top to it's lowest point, so they are straight?
Mdbh
Re: 1991 Haro Edge
« Reply #15 on: April 20, 2012, 11:39 AM »
If you can get the top nut on flat if just leave em on! It will give the nut a bit more to bite on to!
Offline Dannywhac
Re: 1991 Haro Edge
« Reply #16 on: April 20, 2012, 11:44 AM »
I reckon it'll come loose more often if you leave those top two half threads.
Offline sparkysx
Re: 1991 Haro Edge
« Reply #17 on: April 20, 2012, 12:53 PM »
Not worth cutting it down and welding a new thread on?
Offline Dannywhac
Re: 1991 Haro Edge
« Reply #18 on: April 20, 2012, 12:56 PM »
If you've got the welding skills go for it fella  :daumenhoch:
If you're gonna ride it in anger, you'd want to replace the whole steerer tube though I reckon.
Offline sparkysx
Re: 1991 Haro Edge
« Reply #19 on: April 20, 2012, 01:38 PM »
As in, re welding the forks to the steerer? Not doing that! But understand the tale of caution! Annoyed that i have to do anything to it! They are going to have to have to give a part refund or recieve the negative feedback.
Guess I could do this, whats the best way to drill the steerer out of the forks?
« Last Edit: April 22, 2012, 01:42 AM by sparkysx »
Offline sparkysx
Re: 1991 Haro Edge
« Reply #20 on: April 22, 2012, 01:40 AM »
What width wheels do I need for this bike?
whatquid
Re: 1991 Haro Edge
« Reply #21 on: April 22, 2012, 09:26 AM »
haro edge never came with a gyro anyway so if your gonna build it up and not fussed about running a gyro you can just tidy up the top of the stearing tube, and run a stright cable, to replace it will be alot of work....same that someone has done that as the early 90s forks are quite hard to get.......good luck mate.
Offline sparkysx
Re: 1991 Haro Edge
« Reply #22 on: April 22, 2012, 10:09 AM »
I bought one new in 1991, and it had a gyro on it. One of the only reasons I bought it.
Offline sparkysx
Re: 1991 Haro Edge
« Reply #23 on: April 22, 2012, 10:11 AM »
Infact, 3 of us all had the same bikes, and they all had gyro's from new. Seems that some came with gyros and some didn't, but I would like to run a gyro.
whatquid
Re: 1991 Haro Edge
« Reply #24 on: April 22, 2012, 12:57 PM »
no worries.......
