975810 Posts in 138943 Topics by 6371 Members - Latest Member: Robertflamn November 28, 2024, 08:26 AM
RADBMX.CO.UK  |  Mid School BMX (>87) 1989 to 2003 (<05)  |  Mid School ( Keep the faith )  |  Info needed on S&M forks with 14mm dropouts...
Author Topic: Info needed on S&M forks with 14mm dropouts...  (Read 1106 times)
sid1972
« on: April 18, 2012, 08:35 PM »
Hi folks,
I may need a set for next gen dirtbike, are these hard to come by?
Only had 10mm version before, but I want to run the wheels I have - this maybe a total plank type of question so laugh away!  ;D
thanks for any help,
Sid.
Re: Info needed on S&M forks with 14mm dropouts...
« Reply #1 on: April 18, 2012, 08:39 PM »
flat the threads of the 14mm axels to make them fit 10mm drops fella
sid1972
« Reply #2 on: April 18, 2012, 08:42 PM »
 ::) they are hollow axles mate, so I dont think it will work without causing them to break.  :-\
elevensies
« Reply #3 on: April 19, 2012, 10:13 AM »
Not as common as you may think I believe, unless you go for newer ones, or drill out some 10mm??
sid1972
« Reply #4 on: April 19, 2012, 02:38 PM »
 ::) Thanks mate - Any Ideas who stocks the newer forks  ???
elevensies
« Reply #5 on: April 20, 2012, 12:49 AM »
Any s&m dealer wil get you some forks, but I'm sure I have seen some ditch forks with 14mm on eBay recently
Unless you want pitch forks though that is.
I will have a dig around for you.
elevensies
« Reply #6 on: April 20, 2012, 01:21 AM »
There are some pitch forks on eBay, seller has sold quite a lot of s&m mid school stuff, apparently it was her deceased brothers and it looks like he had quite a collection of nice things. She's in Kent, so don't know if that helps either.
I can't post a direct link at the mo. bloody iPad things...
sid1972
« Reply #7 on: April 20, 2012, 04:04 PM »
nice one pal - i've found them, but a radster is helping me out..  :4_17_5:
