975810 Posts in 138943 Topics by 6371 Members - Latest Member: Robertflamn November 28, 2024, 08:35 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  88 GT Performer VS Gasket Remover
Author Topic: 88 GT Performer VS Gasket Remover  (Read 1896 times)
Offline Orange777
« on: April 15, 2012, 08:30 PM »
As I really want to get this project off the ground, I needed to strip the paint off the F&F ahead of sending to sawzall to remove the crushed tube damage.
Looked on the forum on removing powder coat, joined a chemistry forum to understand thermoplatsics and solvents and then headed out to buy respirators, Goggles and all the usual stuff....
£60 and 4 hours later (I ran out of stuff) - I can safely say that Gasket Cleaner & Nitromors both fetch Powder Coat off - HOWEVER - they need the magic banned ingriedent substance.
I am heading back on my lunch Monday to buy more just in case it gets taken off the shelves. You cannot buy this stuff in any normal retailers B&Q etc as it has cancer warnings on the tin. Plus its not green!
Anyway -
Before, a lovely deeep Golden Yellow colour............
Forks were same colour..............
Then - The Introduction of the good stuff
[/img]
Resulting in..............
And not forgetting:
Then I ran out of stuff!!!!!!!!!!!!
RESTORATION ROCKS!!! :) :) :) :) :) :) :) Although doing it in the kitchen will lead to relationship breakdowns...
Offline bigfatolly
Re: 88 GT Performer VS Gasket Remover
« Reply #1 on: April 15, 2012, 09:53 PM »
Top work mate :daumenhoch:
Yes nitromors is shite now hardly touches paint and you have to use loads :idiot2:
Offline Orange777
« Reply #2 on: April 15, 2012, 10:08 PM »
Cheers!!!
Spotted another can of the old school nitro so off to pick up Monday! :)
Offline superbikedan
« Reply #3 on: April 15, 2012, 10:22 PM »
just a little tip, powder coat is not thermoplastic, thermoplastic is dipped in powder at a high temperature
and powder coating is sprayed on as a powder then baked at a high temperature, the paint strippers
are for powder and not plastic :daumenhoch:
Offline Orange777
« Reply #4 on: April 15, 2012, 10:29 PM »
I'll get my coat! :)
Thanks for the info Dan!!! Still wish had sent it you 1st! :)
« Reply #5 on: April 15, 2012, 10:38 PM »
i used a heat gun and a sharp knife to get the powder of my s&m.
takes a while and makes a fookin mess but works if nowt else seems to get it off  :).
« Reply #6 on: April 15, 2012, 11:02 PM »
every one needs to learn to use this stuff, i use it daily and there's not a lot this stuff won't remove
http://www.autopaintsbrighton.co.uk/starchem-paint-stripper-5l-2598-p.asp
listen to the boss ;D :daumenhoch:
Offline GTnumber1
« Reply #7 on: April 15, 2012, 11:04 PM »
+1, listen to the man FFS  ::)
