975804 Posts in 138943 Topics by 6363 Members - Latest Member: V6 DOW November 23, 2024, 02:26 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Aero zytec sealed bearing question.....
Author Topic: Aero zytec sealed bearing question.....  (Read 1505 times)
The Burner King
« on: April 05, 2012, 10:53 PM »
Don't know if anyone has tried this, but is it possible to change the bearings in the hubs of aero zytecs?
They are sealed ones, but inside the bearings are open. I know you can buy sealed bearings but they are normally closed both sides? Could you use a set of that type to replace the zytec ones. The rear bearings in mine sound a bit rough, they look OK and i've greased them but they just don't sound right.
I don't even know what size to get so if anyone can help please let me know.
Cheers J
Re: Aero zytec sealed bearing question.....
« Reply #1 on: April 06, 2012, 12:26 AM »
Got a pic Julian mate - might have some thing that might work or might not  ??? ;D
cheers B  ;)
Offline john4130
« Reply #2 on: April 06, 2012, 12:27 AM »
you could knock them out to see if there's a number on them, then see if a bearings supplier has them or measure the outside o.d, inside o.d and width and check that way.
The Burner King
« Reply #3 on: April 06, 2012, 11:01 AM »
Gonna stick one half of the hub in the oven tonight and take the bearings out, they come out easy once heated up.
The Burner King
« Reply #4 on: April 06, 2012, 11:02 AM »
cheers B  ;)
What you got then B?
J4CK
« Reply #5 on: April 06, 2012, 12:43 PM »
look to b the same size as skateboard bearings  ;)
you could get som super speedy bearrings for
15-20 squids ;)  i reccommend enuff 'black' bearings
simon h
« Reply #6 on: April 06, 2012, 09:08 PM »
Had bearings missing on a set I got my hands on .Took them to my local bearings dealer ,he matched them up no problem,£15 bucks if I remember
« Reply #7 on: April 06, 2012, 09:29 PM »
seemed to remember that the bmx bearing is bigger
need a pic J and then we can see from there mate  ;)
