975882 Posts in 138950 Topics by 6383 Members - Latest Member: moley147 February 17, 2025, 03:44 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Motomag hub question
Author Topic: Motomag hub question  (Read 1249 times)
oldboyburner
« on: April 04, 2012, 09:16 PM »
Hi how do I remove these or are they pressed in front and rear MM2
Offline kalex
Re: Motomag hub question
« Reply #1 on: April 04, 2012, 10:07 PM »
the first pic, this should pop out and there should be a set of bearings in a cage behind this. i think this is the part that the sprocket fits on to and moves the clutch in or out to engage the coaster brake. the 2nd pic should have a smooth drum like look to it where the brake pads fit in so not sure what the splines are. but the main hub area on the rear is i should imagine only done in the factory and not to be replaced.
not sure about the fronts as you can replace the bearing cups on alloy hub skyways, so you may be able to on these. but make sure you get replacement cups first and they will need a big hammer or some kind of press to remove
i'm sure they only came in suntour,shimano and bendix coaster rear
oldboyburner
« Reply #2 on: April 07, 2012, 07:19 AM »
Cheers but the rear one don't move
 in the second pic do you undo the slotted bit in side to remove the outer bit
« Reply #3 on: April 07, 2012, 11:18 AM »
give Wazza a pm/e-mail
 http://vintagemongoose.com/
oldboyburner
« Reply #4 on: April 07, 2012, 11:22 AM »
