975806 Posts in 138943 Topics by 6363 Members - Latest Member: V6 DOW November 25, 2024, 03:35 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  I've got a crank problem too....
Author Topic: I've got a crank problem too....  (Read 664 times)
retrorb
« on: June 19, 2006, 10:29 PM »
I have an oldschool set of 401's with sealed BB. there is a 3" or so shim - does this go within between the two bearing cups when it is in installed or is it used to put  the last bearing in as a sort of hammering tube?
If it is to be fitted in the bike...how the tell will you ever get the bearings out if you need to?
First build.......probably a silly question...
Offline billstup
Re: I've got a crank problem too....
« Reply #1 on: June 19, 2006, 10:54 PM »
It goes in between the bearings so that they still spin freely after the bolts have been tightened up on the axle. When you need to get the bearings out it just moves out of the way  :daumenhoch:
