975808 Posts in 138943 Topics by 6363 Members - Latest Member: V6 DOW November 25, 2024, 07:45 PM
RADBMX.CO.UK  |  New School BMX 2004 - Now  |  New School Park, Street & Dirt  |  Affix Tiny hub Axle replacement??
Author Topic: Affix Tiny hub Axle replacement??  (Read 1156 times)
Sink
« on: March 29, 2012, 11:22 AM »
Anyone know if the Affix tiny front hub takes a certain axle? After a couple of heavy peg landings looks like i've killed the thread :10_2_12: Is it serviceable or knackered?? :'(
Offline fugazi
Re: Affix Tiny hub Axle replacement??
« Reply #1 on: March 29, 2012, 11:54 AM »
Check it's actually the thread on the axle & not just the nut stripped  :daumenhoch: A lot of hubs are generic, just a slightly different shape & graphics on them so if You do need an axle, strip off the cone nuts, knock the axle out & go to a decent BMX shop & They'll sort You out. Failing that there was some of those hubs on Feebay for £15.
Sink
« Reply #2 on: March 30, 2012, 01:06 PM »
Cheers Fugazi  :daumenhoch: After pulling the old axle out, it's f@@ked, both axle and nuts are stripped and the axle is bent. I bought a new hub from the bay as it will be cheaper to rip apart for the axle, bearing and fittings, than sourcing and buying an axle kit   :daumenhoch:
Offline fugazi
« Reply #3 on: March 30, 2012, 03:04 PM »
No problem, good You've got it sorted  :daumenhoch: Bring back 14mm front axles I say!!!
