975806 Posts in 138943 Topics by 6363 Members - Latest Member: V6 DOW November 24, 2024, 03:13 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Hub Bearing Sizes
Author Topic: Hub Bearing Sizes  (Read 522 times)
thesku11s
Hub Bearing Sizes
« on: June 18, 2006, 05:11 PM »
Hi,
Do all hubs take the same size of sealed bearing?
Re: Hub Bearing Sizes
« Reply #1 on: June 18, 2006, 08:16 PM »
No, I believe they do not....  However,  on the side of the bearing will be a code - numbers and letters usually.  Take that code, or the bearing itself to a bearing supplier and ask them for a British or Japanese equivalent  (infinately better than the more common chinese) and they will sort you out. I've found them to be cheaper than from bike shops and better quality to boot.
Hope that helps   :)
