975625
Dannygee
June 27, 2024, 03:12 AM
Cleaning out Seat tube
Topic: Cleaning out Seat tube (Read 897 times)
Knoxxy
March 15, 2012, 09:38 AM »
I'm building a Redline cruiser & went to put seat post in.
It sounds horrible & the post is super tight, and scratched when removed.
Sounds like the tube is full of rust.
Any tips for cleaning out the tube before fitting?
Thanks.
Knoxxy.
Dannywhac
BMX Nerd
return of the whac
Re: Cleaning out Seat tube
March 15, 2012, 09:45 AM »
I use a bottle brush you can get in homebrew shops + a squirt of WD-40 to give em a good blast out
Also check for weld spatter on the inside of the tube where the seat stays meet the seattube - if there is some get a metal file and give it a going over.
"Listen. I don't care what you say. Chlamydia is a soup."
(Phelps, L. 2000)
Knoxxy
March 15, 2012, 02:05 PM »
Great tips.
Thank you!
sawzall
540 Air
March 15, 2012, 08:12 PM »
i use a flexi drive on a drill with a flap wheel
Gary72
Site Supporter
BMX Nerd
March 15, 2012, 10:32 PM »
Also check the slit/hole at the top.
oldschoolib
Rockwalk
March 15, 2012, 10:54 PM »
sawzall x2
skyway67
March 15, 2012, 11:43 PM »
hi had the same trouble so i honed it out at work
animal
Team Moderator
BMX Nerd
MRD Loony & proud
March 16, 2012, 10:06 AM »
If its just rust will the seatpost tube with vinegar. This will clean all the rust off in a couple of hours
