975769
TattooedYorkie
October 06, 2024, 12:10 AM
New School BMX 2004 - Now
Brake cable ?
Topic: Brake cable ? (Read 1193 times)
BENDYCAT ELEVENTEEN
Berm Worm
"Click here for link"
Brake cable ?
February 12, 2012, 01:58 PM »
as there are so many about, i thought i would ask just in case i got the wrong sort
is there a standard length/ then cut down
what wire is used ?
cheers B
Discostu
540 Air
Two's Company
Re: Brake cable ?
February 12, 2012, 03:31 PM »
Just use an odyssey slick one mate you get inner and outer and it is a rear. You can get seperate inners for these as well. Normally around £3
skyway67
Re: Brake cable ?
February 12, 2012, 04:05 PM »
i'm using an oddy slic cable too
i think i cut about 8 inches off it but its still long enough for a bar spin they have loads of rad colours too
Dannywhac
BMX Nerd
return of the whac
Re: Brake cable ?
February 12, 2012, 04:22 PM »
If you're ever going to barspin with a single cable you want a linear cable as the brake can lock-up with a standard coiled brake sleeve.
Oddy do a Slic Linear for about a tenner, or save yourself a few quid and get an Xposure or Stolen one for about £7
"Listen. I don't care what you say. Chlamydia is a soup."
(Phelps, L. 2000)
Re: Brake cable ?
February 12, 2012, 04:25 PM »
If you do cut it down make sure you use very good brake cable cutters. Linear outer is a bitch to get thro
kev-s
900 Air
I bought a site tag and my girth increased by 10%
Re: Brake cable ?
February 12, 2012, 04:43 PM »
trick there is alex, if u have shit cutters then whack the top of em with a hammer!!!!
works everytime
Dannywhac
BMX Nerd
return of the whac
Re: Brake cable ?
February 12, 2012, 04:45 PM »
(Phelps, L. 2000)
Betty
900 Air
Re: Brake cable ?
February 12, 2012, 05:45 PM »
I use a small hacksaw to cut the outer cable...
Does a neater job than Kev's method, i used to do the same but then struggled to push the inner cable through
2 minutes turkish...
Dannywhac
BMX Nerd
return of the whac
Re: Brake cable ?
February 12, 2012, 05:46 PM »
Yeah - always found snips crimped the ends too much - Dremel for the lazy man
(Phelps, L. 2000)
BrianP
Cherry Picker
Re: Brake cable ?
February 12, 2012, 05:47 PM »
If you go for a linear cable, and cut it, make sure you use one of the spare ferrules (normally supplied with the cable) on the cut end of the outer housing - the inner braid has a tendency to slowly 'creep' out if you don't.
Brian
TwoBobRob
Site Supporter
900 Air
Re: Brake cable ?
February 12, 2012, 10:31 PM »
Bendy, to answer the question; no mate. You can't buy the wrong one these days - any brand will do. As others have said, spend another couple of quid on the linear type. A few drops of light oil or GT85 down it when you fit it, bob's yer uncle.
No set length, entirely up to you.
BENDYCAT ELEVENTEEN
Berm Worm
Re: Brake cable ?
Reply #11 on:
February 12, 2012, 11:32 PM »
cheers guys
- it's better to know and learn, than not understand and burn
Brake cable ?
