975811 Posts in 138943 Topics by 6371 Members - Latest Member: Robertflamn November 29, 2024, 09:57 AM
RADBMX.CO.UK  |  New School BMX 2004 - Now  |  New School Park, Street & Dirt  |  NOW IT'S WINDING ME UP A FECKING TREAT **********
Author Topic: NOW IT'S WINDING ME UP A FECKING TREAT **********  (Read 12201 times)
Re: NOW IT'S WINDING ME UP A FECKING TREAT **********
« Reply #50 on: February 08, 2012, 02:39 PM »
so is this to little tube /stem - as running without a gyro will on drop it down about 5mm more ?
« Reply #51 on: February 08, 2012, 02:43 PM »
Oddy Medium lever. Very few people like the small.
Skinnier top plate will allow you to faf around with spacers as I mentioned.
Totally agree that the small oddy lever is crap, and the medium lever is great
Rob, have you looked at how little fork tube there is there? I dont think you'll have room for ANY spacers, even with a thin gyro plate  ???
I have, but that's such a kooky plate he's got there, I'm punting he could maybe use a regular plate and reduce spacing down by half and that would just about be acceptable. Assuming the brake is dialled in spot on..
Bendy - by ditching the gyro plate you gain that extra bit yeah.  You could always drill & tap tabs into the stem.....
Offline Discostu
  • Two's Company
« Reply #52 on: February 08, 2012, 02:49 PM »
It may fit and work ok. The lower you get the gyro/stem the stronger your ride is. But equaly you need to have enough room between the lower gyro tabs and the upper plate for your gyro to travel up and down enough to operate your brakes.  :daumenhoch:
That's why I said to fit your current one upside down and fit the cables and pull the lever. Then you can see if there is enough gyro travel. If the gyro touches the top plate then you may be able to adjust the rear brake closer to the rim. If there isn't enough travel after that then its pretty much game over. Time to fit a single cable system or longer forks. I think you will just about have enough room.  :daumenhoch:  if the gyro doesn't touch the top plate then my plate will do the job for you. :)
« Reply #53 on: February 08, 2012, 02:54 PM »
I honestly don't think you've got enough space to run a plate on that, I'd go for a single cable job if it were mine.
« Reply #54 on: February 08, 2012, 03:00 PM »
right just turn the plate up side down and found everything is a little to close - can't get enough lift to pull slack out of cable, and it's adjusted as far as it can go
so looks like it will be a single cable ~ no gyro - cheers to stu but giving up on the plate working  :daumenhoch: will get you a half for your troubles
also just looked at the rear brakes and there is not pop back - it's about 1-2mm from the pads to rim and not spring back in place - so will have to adjust them on the new single cable
will put all the gyro stuff to one side - might try again one day, but will see
just want to say a big thank you to all in this thread for helping - team effort in helping out a bro  :daumenhoch:
cheers B   ;)
« Reply #55 on: February 08, 2012, 03:00 PM »
right so now what shall we talk about  ;D
Offline Discostu
  • Two's Company
« Reply #56 on: February 08, 2012, 03:10 PM »
Nevermind bendy. Keep the gyro it may be good for a future build. Putting the plate on upside down was the only way to find out if it was gonna be to close for the gyro to travel. New lever and cable then mate. I would also say that the odyssey mid lever is a good one. With a slick cable.  :daumenhoch:
« Reply #57 on: February 08, 2012, 03:44 PM »
i'd get a big hammer.
and SMASHHHHHHHHHHHHHHHHH it right up  :LolLolLolLol:
bof
« Reply #58 on: February 08, 2012, 03:53 PM »
Put the thinner gyro tab on top of the stem if the cable will reach
« Reply #59 on: February 08, 2012, 03:59 PM »
bof - that won't look good  :-\
stu - many thanks for the info - that is what decided it  >:( ;D :daumenhoch:
dordy - can i try on your stuff first  ;D
Offline fugazi
« Reply #60 on: February 08, 2012, 04:09 PM »
If in doubt, get the hammer out  :daumenhoch:
lk_97
« Reply #61 on: February 08, 2012, 04:51 PM »
« Reply #62 on: February 08, 2012, 06:12 PM »
the forks on mine are light - if any thing the bars are heavy
but hopefully the ride is now sorted and just needs a brake  8)
« Last Edit: February 08, 2012, 07:11 PM by BENDYCAT ELEVENTEEN »
« Reply #63 on: February 08, 2012, 06:19 PM »
Bendy. Got a thin demolition giro plate in black here with your name on it. Just cover postage mate.
Offline Betty
« Reply #64 on: February 08, 2012, 06:27 PM »
Have a look on stereo bikes website, all the completes look like they have no spacers so i don't think your steerer has been cut down
Get some new forks, internally threaded, you'll be able to run the gyro with no problems...  :daumenhoch:
2 minutes turkish...
« Reply #65 on: February 08, 2012, 07:19 PM »
yer the top didn't look cut down - think i'm just gonna run a single for the mo - was just hoping to sort it all out with the parts i had on the bike - only took three pages to sort out  ;D
cheers Jaymz for the offer mate - stu offered his as well, but check out mine upside down and it just didn't have the clearance - maybe a U type with the life edges may fit but that will be for a different day  ;)
