975755
TattooedYorkie
September 21, 2024, 01:27 PM
Haro Fusion chainwheel on 2009 Freestyler
Topic: Haro Fusion chainwheel on 2009 Freestyler (Read 2901 times)
sparkysx
Curb Endo
January 29, 2012, 02:30 PM »
I have just bought a NOS Haro Fusion Chainwheel (thanks Jai!)it's going on a 2009 Freestyler and it's a fair bit thinner than the standard chainwheel on it, do I need a new chain and rear sprocket or will it be ok?
Robbo
540 Air
Re: Haro Fusion chainwheel on 2009 Freestyler
January 29, 2012, 02:50 PM »
Should be ok but you will probably need a top hat washer to make it fit
sparkysx
Curb Endo
January 29, 2012, 02:54 PM »
What does a top hat washer do? Any links to the appropriate one?
Betty
900 Air
January 29, 2012, 02:59 PM »
22mm to 19mm reducer washer
Ebay our your local bike shop if you didn't get one with the sprocket
Did you get the pegs to fit?
2 minutes turkish...
HEYWOOD BMX
January 29, 2012, 03:02 PM »
Could be that it`s a 3/32 chainwheel and your current one is 1/8 so you might need a new chain & freewheel.
sparkysx
Curb Endo
January 29, 2012, 03:23 PM »
Yeah it is deffo thinner, I was worried about it slopping around on it. Looks like I may need a new chain and free wheel for it, does the free wheel come off easy or do I need a special tool?
Don't need a top hat washer though.
Didn't get any pegs yet, picked up a new front axle today, will order the pegs later.
sparkysx
Curb Endo
January 29, 2012, 03:26 PM »
What would happen if I just ran it with this chain?
sparkysx
Curb Endo
January 29, 2012, 04:14 PM »
New problem:-
Don't need a reducing top hat washer, but seem to need a thinner one or something....
Standard Chainwheel:-
Fusion Chainwheel:-
The washer is sub-flush on the standard wheel and proud on the Fusion wheel.
On another note, will I need to take a link out of the chain? as the fusion chainwheel is a 43t rather than 44t
Last Edit: January 29, 2012, 04:20 PM by sparkysx
HEYWOOD BMX
January 29, 2012, 04:50 PM »
1/8 chains are too big to fit on most 3/32 cogs.You can buy a freewheel removal tool or your LBS will charge a couple of quid.If the tophat is too thick you can just file it down.
sparkysx
Curb Endo
January 29, 2012, 05:05 PM »
Ok i will file down the th.
Will the chainwheel be in the right line for the sprocket?
Discostu
540 Air
Two's Company
January 29, 2012, 05:51 PM »
dont file it down. just try it on. if it is out of line just pop it out and fit it on the other side!
as far as your chain is concerned it should be fine with either a 3/32 or 1/8th chain on it. it will ride fine. it also helps if the chain line is slightly out as it will have a little more movement.
you may have to take out a link. it depends on your dropout length and whether your running a standard link chain or a half link.
to be honest your thinking to much into these things. just get it on my son!
sparkysx
Curb Endo
Reply #11 on:
January 29, 2012, 06:33 PM »
lol ok,
It's a normal chain, will prob take a few links out.
So I can just turn it around?
Discostu
540 Air
Two's Company
Reply #12 on:
January 29, 2012, 06:54 PM »
if you need to. just fit it and see. same with the chain. then you will know.
sparkysx
Curb Endo
Reply #13 on:
January 29, 2012, 07:08 PM »
Fitting it the way it is in the pic doesnt work will try it your way later.
sparkysx
Curb Endo
Reply #14 on:
January 29, 2012, 08:32 PM »
Shame you can't just take 1 link out, as 2 seems to of brought the wheel too far forward, works fine though.
Discostu
540 Air
Two's Company
Reply #15 on:
January 29, 2012, 08:52 PM »
It's better to have the wheel inwards towards the bb. Than almost hanging out of the dropouts. Also the brake blocks line up easier. Is the chain nice and free without any tight spots? Coz that is how it needs to be.
sparkysx
Curb Endo
Reply #16 on:
January 29, 2012, 09:40 PM »
yeah the chain is nice and free, cheers for the advice regarding turning the washer around, worked a treat! I don't like grinding things down if I don't have too!
