975808 Posts in 138943 Topics by 6370 Members - Latest Member: Robertflamn November 26, 2024, 09:53 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Can I put pegs on front wheel, 2009 Freestyler
Author Topic: Can I put pegs on front wheel, 2009 Freestyler  (Read 1806 times)
Offline sparkysx
« on: January 23, 2012, 07:37 PM »
The axles don't look long enough to put pegs on, how long do they have to be to safely put pegs on?
Cheers :daumenhoch:
Offline Munnyella
Re: Can I put pegs on front wheel, 2009 Freestyler
« Reply #1 on: January 23, 2012, 08:15 PM »
You want the nut to be fully threaded on.
MM
Offline sparkysx
« Reply #2 on: January 23, 2012, 08:52 PM »
If it isn't long enough, can I get a longer front axle for tuff 2's?
adeshere
« Reply #3 on: January 23, 2012, 09:16 PM »
You take the wheel nuts off and use the pegs to hold the wheel on
Offline sparkysx
« Reply #4 on: January 23, 2012, 09:22 PM »
Not gonna work that way with the pegs I want to use, I need to use the wheel nuts aswell.
Can I get a longer front axle?
« Reply #5 on: January 23, 2012, 09:31 PM »
Do you want to use modern style pegs as opposed to the long old school trick nuts, as being mentioned above ?
Modern style pegs only require the axle sticking out about 6mm past the wheelnut .
Take the nut off,, ,peg on ,,,nut back on with a socket extension  :)
Or are you using threaded pegs  :-\
Offline sparkysx
« Reply #6 on: January 23, 2012, 09:48 PM »
I want to use the modern ones, but pretty sure the axle doesn't stick 6mm past the wheelnut, hence my problem
Offline Betty
« Reply #7 on: January 23, 2012, 10:08 PM »
Has it got tuffs on?
Just remove the existing washer from behind the wheel nut on the side you're fitting the pegs on, the pegs won't be much thicker than the washer you've removed...  :daumenhoch:
They'll work fine with tuffs, just don't go doing anything to heavy on em, those 10mm axles will bend easy
2 minutes turkish...
Offline sparkysx
« Reply #8 on: January 23, 2012, 10:15 PM »
Yeah it has tuffs on it, the washer behind the wheel nuts is one of those safety ones that locks the wheel onto the forks.
Offline Betty
« Reply #9 on: January 23, 2012, 10:22 PM »
Chuck it away, unless you plan on riding with the wheel nuts loose you won't be needing it...  :daumenhoch:
Offline sparkysx
« Reply #10 on: January 23, 2012, 10:45 PM »
Ok, say I wanted to keep that washer, can I get a longer axle that fits tuffs?
Offline sparkysx
« Reply #11 on: January 23, 2012, 11:13 PM »
Took one of the front washers off and the axle still only sticks 3.5mm past the wheelnut.
Offline sparkysx
« Reply #12 on: January 23, 2012, 11:32 PM »
Looks like the axle is 140mm, can I just knock that one out and put a longer one in? Does it need to be anything special?
Offline sparkysx
« Reply #14 on: January 24, 2012, 04:27 AM »
couple of pics please  :daumenhoch:
Offline sparkysx
« Reply #15 on: January 24, 2012, 09:08 AM »
Without washer:-
With washer:-
This is a picture of the bike that was sent to me before it was bought, so it seems that it did have a much longer front axle, but for some reason the axle or more likely the wheel was changed before the bike was collected:-
« Last Edit: January 24, 2012, 09:11 AM by sparkysx »
« Reply #16 on: January 24, 2012, 10:16 AM »
great pics cheers  :daumenhoch: now just need a pic of the pegs you want to use  :)
Can can change the axle if you want but its unusual to have to do it... but if that last pic was of the bike you were buying then is pretty weird that it isn't what you got  ???
Offline sparkysx
deeman
« Reply #19 on: January 24, 2012, 01:09 PM »
dude,i have a replacement front axle kit for a tuff,ill measure it now! :daumenhoch:
deeman
« Reply #20 on: January 24, 2012, 01:14 PM »
out of luck dude,sorry this one only measures 135 mm :(
« Reply #21 on: January 24, 2012, 01:16 PM »
just whack the peg on with no washer (use the peg as the washer) should be fine.........hell the tuff axle will bend anyway  :daumenhoch:
deeman
« Reply #22 on: January 24, 2012, 01:21 PM »
i would just buy a set of the old SKYWAY pegs where you use the washer as the nut.less aggro than changing the axle!
« Reply #23 on: January 24, 2012, 01:25 PM »
I need some of those in silver  :daumenhoch:
deeman
« Reply #24 on: January 24, 2012, 01:52 PM »
they are about Rob,come up quite alot.did you want just the one pair?paid £15 a pair on the bay :daumenhoch:
