975882 Posts in 138950 Topics by 6383 Members - Latest Member: moley147 February 17, 2025, 05:41 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Pots mod and Gyro?
Author Topic: Pots mod and Gyro?  (Read 737 times)
750Rush
Pots mod and Gyro?
« on: January 20, 2012, 04:40 PM »
I've just aquired a nice shiny stem with a pots bolt for my Skyway Streetbeat. Now I know the front cable goes down the hollow bolt and the set up on the front brake is reversed. My question is, what is the benefit because surely the rear cable will still get caught on the bars if they are spun? Would I also need to fit a gyro to get complete bar spinning freedom?
Thanks in advance!
delbert
Re: Pots mod and Gyro?
« Reply #1 on: January 20, 2012, 05:39 PM »
Yes.
A giro or similar + potts mod = fully rotating bars :-)
Offline wildon
« Reply #2 on: January 20, 2012, 05:42 PM »
There is still a benefit... with just a rear cable running you could still turn the bars 360 if it was long enough .. you'd never do that with a front cable loose
« Reply #3 on: January 20, 2012, 05:58 PM »
Also it stops the front brake cable catching the underside of your downtube if you didn't have potts mod
deeman
« Reply #4 on: January 22, 2012, 11:48 AM »
lookout for skyway spinmasters Jason.skyways version of a gyro.quite rare but they come up occasionally.failing that odyssey giros easily available on ebay and on here.dont bother with an ACS ROTOR,you will regret it!if you watch old flatland footage like bmx beat you will see the riders constantly flicking their bars back round after they have pulled a trick to detangle the rear cable back in the pre-giro days!i can remember fitting my first spinner bitd,it was a revelation!multiple framewhips etc! :daumenhoch:
