975811 Posts in 138943 Topics by 6371 Members - Latest Member: Robertflamn November 28, 2024, 10:14 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  AD 990 Plate
Author Topic: AD 990 Plate  (Read 799 times)
Offline sparkysx
AD 990 Plate
« on: January 17, 2012, 11:02 PM »
I have one of these to put on my 09 Freestyler, how tight can I do this up on the forks without damaging them? If I do it too tight would it crush the tube?
Offline Dannywhac
  • return of the whac
Re: AD 990 Plate
« Reply #1 on: January 18, 2012, 09:07 AM »
Do it decently tight and add jubilee clips on both arms - the bugger will never move then :)
elevensies
Re: AD 990 Plate
« Reply #2 on: January 18, 2012, 10:10 AM »
agreed,  :daumenhoch:
Offline sparkysx
Re: AD 990 Plate
« Reply #3 on: January 18, 2012, 01:54 PM »
So don't do it too tight, just overnip it?
Re: AD 990 Plate
« Reply #4 on: January 18, 2012, 01:57 PM »
Do it up as tight as you'd fix a caliper brake onto forks, then secure the plate as the others have said. I used big fat zip ties on mine.
Offline sparkysx
Re: AD 990 Plate
« Reply #5 on: January 18, 2012, 02:05 PM »
Yeah I'm gonna use clear cable ties as jubilee clips will look a bit crap.
Offline Dannywhac
Re: AD 990 Plate
« Reply #6 on: January 18, 2012, 02:42 PM »
Make sure the cable ties are beefy then, otherwise you'll still get movement. I like jubilee's = midschool flavour :)
Offline sparkysx
Re: AD 990 Plate
« Reply #7 on: January 18, 2012, 03:44 PM »
Just finished putting it on with no ties or clips and it isn't moving, will see how it goes!
Re: AD 990 Plate
« Reply #8 on: January 18, 2012, 06:13 PM »
No bud, it'll feel fine in the workshop, but will misbehave when you ride it. Especially if it only has a 6mm bolt holding it on. I've seen loads of them snap. The braking effort of an AD style brake is so great it'll overwhelm most fixings.
Grab yourself some jubilee clips or big fat zip ties  ;)
Offline sparkysx
Re: AD 990 Plate
« Reply #9 on: January 18, 2012, 07:40 PM »
ok  :daumenhoch:
