975806 Posts in 138943 Topics by 6363 Members - Latest Member: V6 DOW November 25, 2024, 06:30 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Haro Group 1 Stems.
Author Topic: Haro Group 1 Stems.  (Read 1273 times)
sid1972
Haro Group 1 Stems.
« on: January 11, 2012, 04:57 PM »
Hi folks,
need some advice on these - time lines, colour combinations and did fusion do one? If so what are the differences etc.
Pics would be great also if possible.
Did they mainly come is silver and black?
thanks in advance,
Sid.
sid1972
Re: Haro Group 1 Stems.
« Reply #1 on: January 11, 2012, 10:48 PM »
39 views and no one knows anything - should have posted some pictures of tits...
Sign of the times I suspose..
« Reply #2 on: January 11, 2012, 10:59 PM »
The first ones I recall seeing were in late 85 but the appeared on the 86 Bikes
http://www.harobmxcollector.com/wp-content/uploads/2011/05/1986-Haro-Cataloghires.pdf
not sure about the difference in them as there appear to be a few types about
all the Haro cataloges are here http://www.harobmxcollector.com/gallery/catalogues/
sid1972
« Reply #3 on: January 11, 2012, 11:26 PM »
Thanks fella  ::)
Offline BrianP
« Reply #4 on: January 12, 2012, 11:16 AM »
This is my old one from circa 1985, as far as I can remember:
The white top cap is original colour, and it had a slight pearlescent hint to it.
Underside of stem had "Anlun" cast into it. It cracked across the web underneath, where the hole was drilled for the top Rotor cable to go through :(
Brian  :daumenhoch:
