975811 Posts in 138943 Topics by 6371 Members - Latest Member: Robertflamn November 29, 2024, 11:23 AM
RADBMX.CO.UK  |  New School BMX 2004 - Now  |  New School Park, Street & Dirt  |  Top Hat
Author Topic: Top Hat  (Read 936 times)
Offline sparkysx
Top Hat
« on: January 06, 2012, 04:16 PM »
I was looking at this chainwheel and it says it needs a top hat to go on a 3 piece crank, whats a top hat?
http://www.ebay.co.uk/itm/350512572989'ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2649
Re: Top Hat
« Reply #1 on: January 06, 2012, 04:33 PM »
It's the stepped converter washer. There's a few different ones as it happens, to suit different chainrings & crank axles.
Offline sparkysx
Re: Top Hat
« Reply #2 on: January 06, 2012, 04:46 PM »
So with one of these top hats, this chainwheel should fit a 3 piece?
Re: Top Hat
« Reply #3 on: January 06, 2012, 05:13 PM »
Correctamundo.
It used to be that if you had a one piece crank you just threw the chainring on. If you had a three piece then you needed the top hat washer as the axle is skinnier on a three piece. Like I said, there's a few different ones kicking about and the differences can be tiny. Sometimes very straightforward, sometimes a pain in the arse.
Measure the hole if you're able to do it accurately, chances are you just need a traditional 22/19mm top hat. Give Stodgy a ring at the RADBMX shop - he has a decent collection of various top hats. 01494 761511.
Clean
Re: Top Hat
« Reply #4 on: January 06, 2012, 10:16 PM »
You normally get the top hat set with the Cranks, or the Sprocket, these days, no?  ???
Offline sparkysx
Re: Top Hat
« Reply #5 on: January 06, 2012, 11:33 PM »
Thanks for the info, prob will buy this chainwheel and strip the paint off it so it's just silver.
