975836 Posts in 138948 Topics by 6378 Members - Latest Member: Stevenlaw January 10, 2025, 05:05 AM
RADBMX.CO.UK  |  BMX General  |  BMX Chat  |  volta 2011..??
Author Topic: volta 2011..??  (Read 439 times)
Offline dubber
volta 2011..??
« on: December 31, 2011, 08:43 AM »
whats your thoughts on these?
can get one for about £425 (if they still have them)
•Frame: full Sanko CrMo, b’d DT, 21" TT / 13.66" CS / 74.5°HT
•Fork: New full 4130 CrMo, CNC 1pc steerer, heat treated drop outs
•Cranks: new Salt Plus ( L&R) tub. 3pc crank CrMo, 175mm, 48 spline
•Bottom Bracket: new Salt Plus mid size BB, press fit, sealed bearing
•Pedals: new éclat “Plaza” PC pedals
•Sprocket: Salt Plus 6061 T6 Alloy, CNC, 25T sprocket
•Freewheel: 9T 1-piece cassette driver, L&R switch drive, sealed bearing
•Chain: Salt Plus half-link chain
•Rear Brake: éclat “Unit” u-brake
•Front Brake: Generic calliper
•Levers: éclat “Swift” brake lever
•Bars: full 4130 CrMo bar, 8.25" height, wide style
•Stem: new Salt Plus CNC Alloy front loading stem
•Headset: new Salt Plus int. headset, sealed bearing
•Grips: wethepeople “El Barrio” grips
•Rear Hub: new Salt Plus cassette, 9T L&R switch drive, sealed bearing
•Front Hub: new Salt Plus female hub, 3/8”s bolts, sb,36H
•Rims: new éclat “Trippin” aero double wall rim, 36H (front), éclat “X-odus” straight double wall rim, 36H, welded (rear)
•Tyres: wtp tyres “Grippin” 20 x 2.25" front / “Feelin” 20 x 2.1" rear
•Seat: éclat “Gonzo” Pivotal seat
•Seatpost: Salt Pivotal seat post, Alloy, 155mm
•Seatclamp: integrated slim Steel seat clamp
•Pegs: n/a
•Gyro: NO / removable brake hardware
•Weight: 10.9kg/24.2lbs w/o brakes
•Size: 21" TT
Offline Devilock
Re: volta 2011..??
« Reply #1 on: December 31, 2011, 09:07 AM »
Too bright...!!  ;)
Looks ok...get Twombolts for it!  :daumenhoch:
Re: volta 2011..??
« Reply #2 on: December 31, 2011, 08:32 PM »
I like it, but you need to get a list and pic's of at least 5 for us to see the style and design you after  ;)
