975800 Posts in 138943 Topics by 6362 Members - Latest Member: Bmxflex November 19, 2024, 04:52 AM
RADBMX.CO.UK  |  BMX General  |  BMX Chat  |  MASSIVE thanks to discostu!!!!
Author Topic: MASSIVE thanks to discostu!!!!  (Read 1599 times)
Offline Robbo
« on: December 22, 2011, 01:42 PM »
Stu popped round last night to pick up some bits from me and while here we got talking about a Boa I recently stripped and attempted to polish which came out okish.
Well I had another set of arms for spare and Stu kindly offered to take them away and have a go himself, so bear in mind that at 9pm last night these where in the standard black finish and now not even 24 hours later these are looking SUPERB!!!
I am so pleased with what you have done Stu, MASSIVE thanks and look forward to building these back up for the new bike.  :4_17_5: :4_17_5: :4_17_5: :4_17_5: :4_17_5: :4_17_5: :4_17_5:
Re: MASSIVE thanks to discostu!!!!
« Reply #1 on: December 22, 2011, 01:47 PM »
well done to stu for polishing off the dark Lord  ;)
Offline Discostu
  • Two's Company
« Reply #2 on: December 22, 2011, 01:48 PM »
Cheers mate!
All I need to do now is find one of these front boas with a 6mm bolt for my latest build.  ;)
« Reply #3 on: December 22, 2011, 01:57 PM »
Stu - try Sid1972 as he gave me a red anno'd Boa ages ago I never used so I gave it back to him a month or two back. It was a front with the massive fat bolt that won't fit standard forks, so I assume that's what you mean :daumenhoch:
Offline Pooch
  • funny you should say that..
« Reply #4 on: December 22, 2011, 01:59 PM »
Nice job mate...! The dark lord has some shinny bits.. :daumenhoch:
Griff loves BUM..
rad_pitt
« Reply #5 on: December 22, 2011, 02:00 PM »
 :4_17_5:
Offline Robbo
« Reply #6 on: December 22, 2011, 02:07 PM »
He's after the smaller spindle Spen, I'm in dialogue with someone on the museum about one for him.  :daumenhoch:
Offline Pooch
« Reply #7 on: December 22, 2011, 02:15 PM »
Your a good bloke Rob.. :daumenhoch:
Griff loves BUM..
Offline WINI
  • Sheeping it real ;-)
« Reply #8 on: December 22, 2011, 02:15 PM »
Yep, the 6mm spindles are a bit harder to get hold of, I had to get my two from the Museum.  Mind you, do those fookers ever stop you!  Awesome brakes
« Reply #9 on: December 22, 2011, 02:17 PM »
No worries Rob, I thought the normal sized ones were 4mm but obviously not!
Offline Discostu
  • Two's Company
« Reply #10 on: December 22, 2011, 02:21 PM »
If I can't get hold of a 6mm one I will look into the bigger 10mm type and turn down the shaft to 6mm. It depends on price. Let's see what Robbo comes up with first :daumenhoch:
At least I know it can be polished up ok!   ;D
Offline Darren KAP
« Reply #11 on: December 22, 2011, 02:26 PM »
  Nice job there Stu ,  did Rob show you his porn collection  ;) :LolLolLolLol:
Offline Discostu
  • Two's Company
« Reply #12 on: December 22, 2011, 05:47 PM »
I tried to dib the porn collection but Robbo wanted to keep it for himself. Bloody pervert!!!
I did get a quick pic of his anal dildo though!
 :2funny: :2funny: :2funny:
Offline Robbo
« Reply #13 on: December 22, 2011, 05:50 PM »
WTF!?!?!?!
You fecker Stu  :knuppel2: :LolLolLolLol:
Maybe you could polish that for me with your tongue!!!!  :2funny:
« Reply #14 on: December 23, 2011, 07:05 AM »
didn't you get one from me?  ??? or who did I sell that to? was it Robbo?
« Reply #15 on: December 23, 2011, 07:11 AM »
Good work Stu :daumenhoch:
Offline Discostu
  • Two's Company
« Reply #16 on: December 23, 2011, 08:35 AM »
you didnt sell it to me ed.  it must have been robbo :)
thanks for all the nice comments.  i thought i had better do my bit to make darth robbo's latest build look the tits. ::)
another bike of the month contender me thinks  ;)
Offline WINI
« Reply #17 on: December 23, 2011, 08:42 AM »
Yeah Ed, I got the rear from you and ended up buying another set from the States just to get the front to match
Love the look of the polished ones!  Sweeet!
punkdSICO
« Reply #18 on: December 23, 2011, 10:36 AM »
Very sexy!!  So, what were the steps to get them looking so hot?  Strip the paint, wet&dry upto about 1200, polish-ta-feck…??
Im still not sure about how to bling chrome.  With say, a aluminium stem, you can wet&dry until you bleed, then polish.  But, when something is chrome plated Im guessing wet&dry will remove the thin chrome layer..
Good results!!
Paul
Offline Discostu
  • Two's Company
« Reply #19 on: December 23, 2011, 11:52 AM »
The steps are as follows.
1- strip the brake arms using paint stripper. I used nitromors in a green tin. This took an hour and a half as they had been powdered.
2-file down any rough edges/casting marks. I used a mixture of files and my belt sander with 180grit.
3-polish up. I use a polishing kit I bought from eBay. It contains a cone shaped arbour that fits into your electic drill. This then has 3 different sizal mops and 3 grades of polishing block. You start with the course mop and polish. This will remove all the rubbing down/filing marks. Then you go down to the medium course mop and medium course polish. Once you reach this stage you can tell if there are any bits you have missed with the course mop. So you go back to the course mop and course polish and polish the marks out. Once they are gone you then go back to the medium mop again. When your happy you clean it up with a cloth and give it a final polish using the 3rd buffing mop and the buffing polish. You should now have a mirror finish like this.  :daumenhoch:
The drill I use is a black and decker with a screw in handle that is gripped into a vice. It also has a lock button so the drill will turn without having to keep the button pressed down.  It is easier to hold your work piece against the buffer than to hold the drill/buffer against the work piece.
Beware the metal gets very hot so gloves need to be used. And also you get filthy :)
You can polish chrome but it is hard to get good results. Also chrome is only microns thick so it is easy to polish through. I normally have a go. But with a view to getting it rechromed if it looks shite!  :daumenhoch:
« Last Edit: December 23, 2011, 11:57 AM by discostu »
punkdSICO
« Reply #20 on: December 23, 2011, 12:43 PM »
Thanks for the write up, Mr Disco - very helpful..
Paul
