975810
Robertflamn
November 28, 2024, 06:35 AM
Chrome fork issue
Topic: Chrome fork issue (Read 599 times)
Tonto
Curb Endo
Chrome fork issue
December 15, 2011, 04:41 PM »
Right I have a set of forks I need to strip and recrome they are a lil batterd so need to shift some dents do I have to fill wiv weld and grind back down in order to get them chrome again ?
Discostu
540 Air
Two's Company
Re: Chrome fork issue
December 15, 2011, 04:54 PM »
Yes or braze. The finish also has to be good. As the chromers polish the metal to a mirror finish before chroming. If the metal is in a poor state the chromers will either refuse to do them or tell you they will be rough in that area. The finish needs to be down to 500grit minimum without any imperfections for a top chrome job
deeman
December 15, 2011, 05:11 PM »
The chromers I used filled a ding in my bars with silver solder prior to chroming!might be easier than grinding back weld!
Discostu
540 Air
Two's Company
December 15, 2011, 06:38 PM »
Yes that is also correct silver solder is also good for a repair. And easier to sand/file down. But make sure you use the high temperature solder.
Chrome fork issue
