975811 Posts in 138943 Topics by 6371 Members - Latest Member: Robertflamn November 28, 2024, 04:04 PM
RADBMX.CO.UK  |  Old School BMX 1980 - 1988  |  Old School Freestyle (frame stands and kickturns galore!)  |  Brake Setups
Author Topic: Brake Setups  (Read 9114 times)
deeman
Re: Brake Setups
« Reply #25 on: December 11, 2011, 05:01 PM »
Found boa's to me the best , run em on all my riders with tech 77, very hard to get 6mm, good job I pick loads of sets up years ago  Dead cheap :daumenhoch:and no
So you've got the european boa mountain then  ;D
Anyone got the ultimate mag pad?
Has anyone used the soft clear pads I keep seeing?
Jon,the new clear pads work brilliantly on mags,they just tend to squeak alot! :daumenhoch:
Coaster
Re: Brake Setups
« Reply #26 on: December 11, 2011, 06:28 PM »
Kool D, what make are you using?
deeman
Re: Brake Setups
« Reply #27 on: December 11, 2011, 10:51 PM »
I had a pair of savage clear pads on the bike when i took the endo pics.I've got some SKYWAY tuff freestyle pads on it now though as thats what i had bitd,and that bike is going on the wall,but I'll probably go for the clears again for the rider i'm builidng!The SAVAGE ones i used are i think 5.99 on ebay,they come with different colour inserts too :daumenhoch:
« Last Edit: December 12, 2011, 08:20 PM by deeman »
Coaster
Re: Brake Setups
« Reply #28 on: December 12, 2011, 07:20 PM »
I'm running the new skyway pads, their ok but nothing to write home about. I've also tried eagle 2's which are fairly similar  ???
Offline Gnarlyscoots
  • BANNED
Re: Brake Setups
« Reply #29 on: December 12, 2011, 07:30 PM »
You have to sand the eagle II's a little first bro to get rid of the smooth surface. Worked for me on Z's, Peregrine's and Skyways  :daumenhoch:
BANNED
Coaster
Re: Brake Setups
« Reply #30 on: December 12, 2011, 07:51 PM »
I did give 'em a quick rub but maybe not enough :) They're ok but I think I just expected a bit more really...................
Offline Wadz
  • Ride Ride Ride!!
Re: Brake Setups
« Reply #31 on: December 12, 2011, 08:15 PM »
 I Use skyway pads on my graphites not the newer version all over eBay but the older type from 2007 ish , only seen them in black and white, i think there made by coolstop, there very soft and work brilliantly but also wear out very quick.
  • BANNED
Re: Brake Setups
« Reply #32 on: December 12, 2011, 08:25 PM »
Don't forget you need to fit them right with the trailing edge nearly touching the rim so it applies first upon braking and then the front comes in after  :daumenhoch:  Don't remove the trailing edge or they don't function properly  :P
Have you tried the Eagle II Salmon's dude  ??? They have something added apparently  :-\  Probably glass  :2funny:  but they work awesome  :daumenhoch:
Hard to get the threaded version of them now though  :(
« Last Edit: December 12, 2011, 08:29 PM by FreestyleRider »
BANNED
Coaster
Re: Brake Setups
« Reply #33 on: December 12, 2011, 08:29 PM »
Yeh dood I think I know which skyway pads you're on about
I'm running skyways dood :-\ so I'm trying to use white or clear pads but I've heard they are wicked on rims
« Last Edit: December 12, 2011, 09:16 PM by Coaster »
deeman
Re: Brake Setups
« Reply #34 on: December 12, 2011, 08:41 PM »
mate,the clear pads bite right from the off,if you still have no stopping power check the brake setup! :daumenhoch:
