975755
TattooedYorkie
September 23, 2024, 01:10 PM
Fitting a freewheel
Topic: Fitting a freewheel (Read 583 times)
lk_97
Fitting a freewheel
December 08, 2011, 10:07 PM »
This is a bit of a stupid question, but I've never had to do it before, but I have a wheel with no freewheel, is it just a case of screwing it on, or do you need a certain tool?
58 delray
Site Supporter
900 Air
Re: Fitting a freewheel
December 08, 2011, 10:10 PM »
put some grease on the threads then screw it on, once the wheel is fitted to the bike put your brake on then stand on the pedals and it will tighten up the last little bit
Badbaldie
900 Air
December 08, 2011, 10:11 PM »
so you dont "cross thread " the freewheel turn it the wrong way first so the threads line up correctly
Spen69
Site Supporter
Tail Whip
It was less than TWELVE parsecs.... .
December 08, 2011, 10:12 PM »
Lucas, as Andy said make sure you grease the threads and it will help to remove it if you need to ;-)
lk_97
December 09, 2011, 10:16 AM »
Ok thanks guys
Fitting a freewheel
