975822 Posts in 138946 Topics by 6374 Members - Latest Member: Boults December 26, 2024, 07:56 AM
RADBMX.CO.UK  |  BMX General  |  BMX Chat  |  Any body shine any light on this??
Author Topic: Any body shine any light on this??  (Read 477 times)
VWmk2
« on: November 30, 2011, 10:35 PM »
Recently got hold of a GT Dyno that's had the frame powder coated (which I thought was causing the problem below but after further investigation I think not) and was having problems with the rear wheel moving forward under tension causing me to whack my shins on the pedals after the chain was coming off :angrysoapbox:  :D
I whipped the BMX  upside down to re tension the chain and tighten the wheel back up and found that the right hand side drop out (looking from the back of the BMX) is slightly bent
You can see a slight bend at the place of the axle
This is the left that's much straighter
I didn't notice it was bent till I tried to take the wheel off but couldn't because of the bend!!
Is this normal lads ? Im not to clued up on wheel widths so if some one can educate me fire away  :daumenhoch:
I think the slight bend may be causing the wheel bolt to not tighten flush with the frame and there for wont be getting a nice grip/hold causing movement, kind of the same reason I thought the powder coat was to blame as its scuffed and gouged out
One more thing, i don't think i can tighten the bolt up any more as they feel as if there going to strip the threads :(
Any advice is much appreciated
Garry  :daumenhoch:
Re: Any body shine any light on this??
« Reply #1 on: November 30, 2011, 10:56 PM »
Looks OK to me but your wheel is on backwards :daumenhoch:
Sprocket should be on RHS
Offline diesel
« Reply #2 on: November 30, 2011, 10:56 PM »
Its fairly normal, just pop a set of chain pulls on, that'll keep it all in place
VWmk2
« Reply #3 on: November 30, 2011, 10:57 PM »
It is mate the BMX is upside down in that pic  :D
Offline 58 delray
« Reply #4 on: November 30, 2011, 10:58 PM »
chain tensioners  :daumenhoch:
VWmk2
« Reply #5 on: November 30, 2011, 11:01 PM »
Yeah was looking into this, any recommendations or are they all round about the same build quality?
VWmk2
« Reply #6 on: November 30, 2011, 11:05 PM »
if he's sharing ill have some too  ;D
« Reply #7 on: November 30, 2011, 11:08 PM »
To busy looking at books at the same time :LolLolLolLol:  Must look harder :-[
Offline 58 delray
« Reply #8 on: November 30, 2011, 11:11 PM »
profile are good mate  :daumenhoch:
thecrooch
« Reply #9 on: December 01, 2011, 11:15 AM »
single bolt are better than double... Profile are good but bloody pain in the ass to fit with double bolts.  loads on fleabay only thing you need to know is if the axle is 10mm or 14mm.
