975808 Posts in 138943 Topics by 6370 Members - Latest Member: Robertflamn November 26, 2024, 06:32 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  What takes it off ?
Author Topic: What takes it off ?  (Read 1966 times)
What takes it off ?
« on: November 29, 2011, 12:58 AM »
Is there any thing that takes the black off a tange 300 headset ?
cheers B  ;)
Offline wildon
Re: What takes it off ?
« Reply #1 on: November 29, 2011, 01:08 AM »
Are they anodised  ???  oven pride if so
« Reply #2 on: November 29, 2011, 01:38 AM »
it's not anno on these as far as i know, it's some thing far stronger  ???
« Reply #3 on: November 29, 2011, 09:55 AM »
Mother's Pride, or Hovis.
Warburtons if it is tough to shift (only in "thick" though - the thin slices are not so good).
Offline mattbloke
« Reply #5 on: November 29, 2011, 11:37 AM »
The L.A.P.D. ?
« Reply #6 on: November 29, 2011, 11:18 PM »
had it in oven pride before - it was in for a hour and  and nothing - tried nitromors = nudda thang
don't think the gasket stuff is going to work DD
it's like a chemical way it has been put on - it's thin layer of baked on stuff ?
any one know  :'(
« Reply #7 on: November 29, 2011, 11:37 PM »
Is it an alloy headset or steel
If it's alloy it could be hard anno like on Pro class III rims well hard to remove , try caustic rather than Oven pride
If it's a steel headset  it could be a type of black chrome plate ,,, in which its take it to a chromers for stripping
Failing these ,,, have you tried sanding  it not too hard  :-\
or big chisels and angle grinding  :D
« Reply #8 on: November 29, 2011, 11:45 PM »
steel i think  :D ;D
and i think you right mate - it's like a black chrome plate
i can stand there for hours on each piece on the polishing mop  ::) was just hoping there would be a quicker way with some chemical stuff  :'( ;D
rad_pitt
« Reply #9 on: November 30, 2011, 02:13 AM »
steel i think  :D ;D
I think it's stained Bendy.. Retro Rich on BW polished one up with some good results. Give him a nudge, he may be able to help mate  :daumenhoch:
rad_pitt
« Reply #10 on: November 30, 2011, 02:18 AM »
You can just about make it out in this pic:
sid1972
« Reply #11 on: November 30, 2011, 09:51 AM »
 the top nut is black chrome - hence way you are having problems... got one in the cellar the same.
its steel so they could not be annodised, so they used a chroming/plating system instead.  ;)
