975837 Posts in 138948 Topics by 6379 Members - Latest Member: McChippy72 January 13, 2025, 08:37 AM
RADBMX.CO.UK  |  BMX General  |  BMX Chat  |  Gearing question ?
Author Topic: Gearing question ?  (Read 1582 times)
Offline monkeybat
Gearing question ?
« on: November 23, 2011, 03:04 PM »
I have a lower mounted(chainwheel) ad990 brake, going to use an Odyssey evolver 2(lowest) and getting some 9 tooth wheels. What size sprocket should I get up the front so it misses the brake and is ok for gearing.
Cheers Steve.
Re: Gearing question ?
« Reply #1 on: November 23, 2011, 03:05 PM »
25T for ok gearing, fingers crossed for missing the brake!
Offline Dannywhac
  • return of the whac
« Reply #2 on: November 23, 2011, 03:09 PM »
Get a 10t maybe (and save eating chains up with a 9t)?
Seen this done (but don't recommend it) - grind down the 990 lugs on the frame for a lower brake. Really again though, don't recommend it.....
« Reply #3 on: November 23, 2011, 03:31 PM »
Which ever way you go for gearing, ie 9/25 or 10/28 make sure you have a look on Porkchop's site for the retro snowflakes he's just done - they are mint and a change from the slightly soul-less ones out there at the moment :smitten:
Plenty of colours and plenty of sizes - here's the little 25T :daumenhoch:
http://www.porkchopbmx.com/Chop-Saw-SNOWFLAKE-19mm-spindle-chainwheel-25T-BLUE-CS-SNOWFLAKE-25T-BLUE.htm
Fingers crossed on the chain missing the brake lugs though, it's a bit of an issue if it doesn't :shocked:
« Reply #4 on: November 23, 2011, 03:35 PM »
So what rear hub are you using? Not that many cassette 10mm jobs  ???
I think you might struggle though on clearence
« Reply #5 on: November 23, 2011, 03:37 PM »
What's the deal with 9t drivers eating chains?
I was just about to buy a 25T (now I want that snowflake!) for my old pk ripper, using a Nankai freehub with a 9t driver.
« Reply #6 on: November 23, 2011, 03:44 PM »
Well Rob, you know me mate - I suspect some sort of cutting equipment will be involved and hopefully we can engineer a solution to the issue or resort to some kind of petrol-powered tool answer :shocked: :2funny:
Greame - I've just ordered that very snowflake and let's face it, they are fookin cool - he does them in all the sizes though, so what gearing are you currently running ???
« Reply #7 on: November 23, 2011, 03:49 PM »
Well I have the wheel I want to use on the bike - a 32 spoke KHE wheel with a 9t Nankai freehub.
So I guess it's gonna be 25T up front.
No brake issue for me, as it has a V brake on the seatstays.
Just wondered about 9t drivers eating up chains?
At this stage should I change the 9t driver for something bigger?
« Reply #8 on: November 23, 2011, 03:58 PM »
Never heard of it myself graham.......thought 9t was the standard nowadays?
By the way, I've got one of those snowflakes and they are sweet  :smitten:
« Reply #9 on: November 23, 2011, 05:55 PM »
Gra - you just need to get a current chain mate, you should be ok. Some chains early on fouled as they tried to get themselves around a 9t driver. The industry soon cottoned on though and chains (and drivers I suspect) evolved into things that once again work nicely together.
I have a KHE (I think) halflink chain and run 25/9 and my bike is of course silky smooth.
Much like myself.
« Reply #10 on: November 23, 2011, 06:07 PM »
Much like myself.
Thanks Rob. KHE halflink chain it is!
Hopefully this thread can squash the 9t drivers destroy chains theory.
Offline Dannywhac
« Reply #11 on: November 23, 2011, 06:28 PM »
Don't get me wrong - wasn't saying you'll immediately destroy a chain by having a 9t driver, but if you ride a lot (in my experience) you'll get through chains more.
Rob's right that more recent chains cope with this a lot more, but is a fact that 9t goes through more chains than 10t - have a butchers here:
http://chain-guide.com/basics/2-2-1-chordal-action.html
Explains sort of why - also explains why there'll never be an 8t........
Offline Betty
« Reply #12 on: November 23, 2011, 06:58 PM »
Cheers Steve.
What frame is it going on?
2 minutes turkish...
« Reply #13 on: November 23, 2011, 07:03 PM »
Danny..... isn't there an 8t out there?  Matched to a 23t chainring. I'm sure I've seen it....
Not that I would run one though. It' a lot of horsepower going through very few teeth.
Gra - check with Stodgy first mate. And be sure to put it on the right way round.....  ;)
« Reply #14 on: November 23, 2011, 07:19 PM »
Ah right!  I don't ride enough I don't think, to get through chains.
Offline Dannywhac
« Reply #15 on: November 23, 2011, 07:52 PM »
Oh christ......
http://www.missionbmx.com/products/wheel-accessories/8t-driver
Maybe I should change 'also explains why there'll never be an 8t........' to 'also explains why there should never be an 8t........'  :shocked:
« Reply #16 on: November 23, 2011, 10:04 PM »
Offline monkeybat
« Reply #17 on: November 24, 2011, 09:40 PM »
Hi Guys, well I have a Schwinn Hydramatic Jay Miron sig version. Its a mid school bike, yep heavy and was thinking of ways to make it more rideable. New school wheels 9 t cog small sprocket up front but the brake is situated down stairs. Was asking Sawzal about putting the lugs up top but to much effort for this project. So a Odyssey evo 2 brake a 9 t rear cog and a 30 or 36 cog up front.
Offline Betty
« Reply #18 on: November 24, 2011, 09:46 PM »
With a 30 or 36 up front you won't want a 9t at the back
30/11
36/13
You might not have enough clearance to run 25/9 on that frame, more than likely the brake lugs will be too tall...  :-\
Offline monkeybat
« Reply #19 on: November 24, 2011, 10:53 PM »
A 36 / 14 clears a old ad990 with space to boot and a Odyssey evo2 is even shorter in height so I have to test it out.
« Reply #20 on: November 25, 2011, 12:44 AM »
Get a 13T Oddysey freewheel on a flip-flop hub and run 36/13 like I do. Plenty of coping clearance for the average rider and should clear your brake.
