975755
TattooedYorkie
September 20, 2024, 08:19 PM
Removing a freewheel without the proper tool
Topic: Removing a freewheel without the proper tool (Read 1574 times)
Rodgy1970
November 22, 2011, 08:40 PM »
Tried two tacks so I could put it in the vice and take it off but this didn't work.
Full on attack with the grinder, then combination of hammer and chisel and vice and off it came.
Jaymz
Team RAD
My life is Radbmx
Posts: I am a geek!!
I'm not FOOKING Dave
Re: Removing a freewheel without the proper tool
November 22, 2011, 08:52 PM »
bloody hell, a hammer and screwdriver has always done the job for me, that must've really been on there
Peter J
BMX Nerd
I have issues
November 22, 2011, 08:56 PM »
Never had one stick on that bad
Did you damage the hub at all ?
Love your determination
I might actually build a bike this year instead of just hoarding parts
oldschoolace
Team Moderator
Double Flip Whip
Bodger
November 22, 2011, 09:00 PM »
Shit dude you really went at that!
Gnarlyscoots
Riding with Stabilisers
BANNED
November 22, 2011, 09:01 PM »
dib dobs depending if its a 14T or 16T or 0T
BANNED
animal
Team Moderator
BMX Nerd
MRD Loony & proud
November 22, 2011, 09:03 PM »
love a good trashing session
BENDYCAT ELEVENTEEN
Berm Worm
"Click here for link"
November 22, 2011, 09:10 PM »
I have done a couple that way and the satisfaction when it all comes off is wonderful
top job
rad_pitt
November 22, 2011, 09:46 PM »
john4130
Look Back
November 22, 2011, 11:27 PM »
i always used a hammer and chisel until one got me beat, got a bit of 1/2" square bar and cut it to fit into the grooves on the freewheel. drilled a hole in the centre of it so i could bolt through the hole for the axle then clamped the square bar in the vice and just unscrew the wheel. took about 10 seconds to unscew compared to the half hour battering it with a hammer and chisel and ending up with bloody knuckles when you swing and miss.
Rodgy1970
November 22, 2011, 11:53 PM »
didn't think it was gonna come off at all so just went for it
was really pleased when the drift moved and i had managed not to wreck the hub or the rim
sid1972
November 26, 2011, 07:20 PM »
been there mate...
Welded a metal bar vertically to one I had and smacked feck out of it, that did the job!
cannot beat a knockometer!
Dark Diggler
Berm Worm
Reply #11 on:
November 26, 2011, 07:44 PM »
Just crush the freewheel in a vice and turn the wheel anti clockwise, do about 3 or 4 a month at work
kev-s
900 Air
I bought a site tag and my girth increased by 10%
Reply #12 on:
November 27, 2011, 10:19 AM »
jesus
no need for that!!
all i do is remove the centre lockring, take off the teeth ring and catch all the bearings and pawls, so ur just left with the freewheel's bare body on the hub which then can be clamped in a vice and just twisted off
that way u can just rebuild the freewheel and you have caused no damage
Dark Diggler
Berm Worm
Reply #13 on:
November 27, 2011, 10:28 AM »
Apologies, I assumed we were at the point where the freewheel is fooked and has no value, my method is used when replacing a shagged ungreased freewheel from a hub, quickly and efficiently. Or if you can't be arsed stripping the £4 freewheel
