975808 Posts in 138943 Topics by 6370 Members - Latest Member: Robertflamn November 26, 2024, 03:55 AM
RADBMX.CO.UK  |  New School BMX 2004 - Now  |  New School Park, Street & Dirt  |  odyssey thunderbolt set up help
Author Topic: odyssey thunderbolt set up help  (Read 1209 times)
Offline HARORIDER
« on: November 20, 2011, 06:42 PM »
hi guys need some help
setting up thunderbolts pretty much same as twombolts-installed them pretty easy and spin nicely but the more i tighten up the spindle bolt the stiffer they get and then do not spin so nice  used all the spacers according to the manual etc so not sure what if anything i have done wrong
thanks in advance   :daumenhoch:
Offline Betty
Re: odyssey thunderbolt set up help
« Reply #1 on: November 20, 2011, 06:46 PM »
Sounds like the tube spacer in the bb isn't long enough, add a thin washer in there and try again...  :daumenhoch:
2 minutes turkish...
gobshite
« Reply #2 on: November 20, 2011, 06:57 PM »
this,
Offline HARORIDER
« Reply #3 on: November 20, 2011, 07:39 PM »
i thought this but if i add a washer to the tube spacer whats the trick for keeping it together while you push the mid bearings back in :-\
« Reply #4 on: November 20, 2011, 07:53 PM »
Leave the crank in paulie
Offline HARORIDER
« Reply #5 on: November 20, 2011, 08:42 PM »
:-\ you have to take bearing out to get at tube spacer don't you  :-\
gobshite
« Reply #6 on: November 20, 2011, 08:44 PM »
Leave the axle in  the fully inserted right side bearing while you tap carefully around the left side bearing to re insert the bearing paulie
Offline Betty
« Reply #7 on: November 20, 2011, 08:45 PM »
What Pete's saying is once you've knocked one bearing out put the crank back in to hold your tube spacer and extra washer in place while you whack the bearing back in...  :daumenhoch:
Offline HARORIDER
« Reply #8 on: November 20, 2011, 09:15 PM »
gotcha  :daumenhoch: cheers guys  :daumenhoch: what's really annoying is,is that i married it up and it looked like the tube spacer was spot on,just needs a bit of fine tuning  :daumenhoch: :daumenhoch:
Offline HARORIDER
« Reply #9 on: December 05, 2011, 04:39 PM »
all sorted cheers guys was just tube spacer  :daumenhoch:
