975866 Posts in 138950 Topics by 6382 Members - Latest Member: bmxbaz January 30, 2025, 11:42 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  haro sport 2006 brake problem
Author Topic: haro sport 2006 brake problem  (Read 3107 times)
Offline Tefore
« on: June 04, 2006, 05:29 PM »
well chaps. ive just spent the best part of 2 hours pulling my hair out
trying to understand how the back brake is fitted (cables) . has anyone built up there
06 sport yet if so be a pal and put on here or pm me a pic of the rear brake with how the cables
fit will yuz. :-[
brimfull
Re: haro sport 2006 brake problem
« Reply #1 on: June 04, 2006, 05:49 PM »
Here you are mate
The cable comes from the gyro and around the seat post-some bikes have a hole through but these don't.The saddle cable joins up the two arms and then the cable from the gyro clamps on to that.It helps if you've got one of those tools that holds the blocks against the rim as you fit the cables but not vital.Just connect all the cables up with the adjusters in and then you can wind them out when it's all connected up.Hope this helps mate-I'd never done one either but they do work well when set up right  8)
Steve
Offline BrianP
« Reply #2 on: June 04, 2006, 06:01 PM »
it's almost there, but not quite correct.
the straddle cable hanger should actually be using a longer cable and should be positioned on the other side of the seattube (in front of it).
this way, you won't get the paint scraped off by the cable from the gyro, nor will you be losing any braking effort with the cable rubbing against the seattube...
hope this helps.
Bp.
« Reply #3 on: June 04, 2006, 06:03 PM »
should'nt you join up that bit in front of the seat tube ?.
the cable from my brake fits on the brake with the hoop in front of the seat tube.
Offline BrianP
« Reply #4 on: June 04, 2006, 06:06 PM »
yep, that's what i'm sayin.
we need a pic to make it crystal...
anyone?
Bp.
« Reply #5 on: June 04, 2006, 06:09 PM »
lol sorry mate i never saw your reply when i was typing.
Offline BrianP
« Reply #6 on: June 04, 2006, 06:15 PM »
lol, no probs mate ;)
hey wasn't there a similar query to this a day or two ago?
think there may have been a pic with it?
Offline BrianP
« Reply #8 on: June 04, 2006, 06:33 PM »
get a stiffy plate on the caliper
looks at os boy's last night it was flexing the frame (not uncommon)
on the front the tektro seems ok. thicker tubes . . .
Offline Rombloke
  • do one
« Reply #9 on: June 04, 2006, 06:34 PM »
needs to be like this.....make the straddle sit in front of the seat tube, and 'straddle' around it....you will end up garotting your frame like that.
Dave
haro, how do you do
Offline Tefore
« Reply #10 on: June 04, 2006, 06:49 PM »
thanks for all your help chaps.
dave that is how i have mine now i just thought it strange
works great now though. i will put a pic on in a bit of how ive done it
Offline Tefore
« Reply #11 on: June 04, 2006, 08:24 PM »
here is how i have done mine. not sure if its totally right but stops a treat
Offline Rombloke
  • do one
« Reply #12 on: June 04, 2006, 08:36 PM »
front tyres still on back to front tho....lol... ;)
Dave
haro, how do you do
Offline billstup
« Reply #13 on: June 04, 2006, 09:40 PM »
Get them bars pulled back a bit too Paul, they should follow the line of the forks, you don`t need to have them as far forward as the old school bikes as the frames is longer  :daumenhoch:
Offline Tefore
« Reply #14 on: June 04, 2006, 09:52 PM »
cheers bill.
force of habit i think
« Reply #15 on: June 04, 2006, 10:26 PM »
looking good paul.
spin the front wheel round mate  :daumenhoch:.
Offline Wayne Ryder
« Reply #16 on: June 04, 2006, 11:13 PM »
They put Tektro brakes on these bikes? They're only trimoly?
I'm glad you guys like them, I definitely don't.
Offline bmxmatt1974
« Reply #17 on: June 04, 2006, 11:58 PM »
get that seat lower aswell :daumenhoch:
brimfull
« Reply #18 on: June 05, 2006, 12:27 AM »
Can't be arsed to change it now cos it works so well.
wolfybmx
« Reply #19 on: June 05, 2006, 01:26 PM »
now ive stop laughing  ;D
ok guys im very disapointed in the quality of ya workmanship. if you all wanted to know how it works why did ya not ask a proffessional mechanic.
this is how it goes boys and girls. that black piece of plastic is not a packing piece.
from ya own and one and only wolfy :angel:
« Reply #20 on: June 05, 2006, 06:44 PM »
Wolfie.....  Not that I want to piss on your chips,  but even though I know your setup is factory correct,  I far prefer the setup the others have shown. Its how i run my brake, and always will.  There are no frictional losses, whereas with your setup as the lever is pulled the frictional losses are compounded as the straddle tries to garrot the seattube.
Also,  I would space the blocks so as to allow a wider gap between brake arms;  helps with the old leverages a bit.
Just my tuppenceworth......   ;)
Offline Rombloke
  • do one
« Reply #21 on: June 05, 2006, 07:02 PM »
my mirra came with that criss-cross set up and didnt work at all, thats why i went for that bigger straddle, as the factory one was just letting the cables rub the paint off the frame, never a good idea...but when i went for the more direct route(not criss cossed) my brakes seemed to work spot bollock on.
Dave
haro, how do you do
motomagII
« Reply #22 on: June 05, 2006, 07:20 PM »
first thing i changed on me flair was to get rid of the cale guide round the tube and uncross the cable as it was already set up.works a treat . perfection isnt always as it should be . :LolLolLolLol:
wolfybmx
« Reply #23 on: June 05, 2006, 07:29 PM »
each to their own as they say :)
Offline BrianP
« Reply #24 on: June 05, 2006, 08:07 PM »
anyone ever used the sst amplifier thing u get on some complete bikes?
