975811 Posts in 138943 Topics by 6371 Members - Latest Member: Robertflamn November 29, 2024, 03:02 PM
RADBMX.CO.UK  |  New School BMX 2004 - Now  |  New School Park, Street & Dirt  |  GYRO OR NO GYRO THAT IS THE QUESTION ????
Author Topic: GYRO OR NO GYRO THAT IS THE QUESTION ????  (Read 1202 times)
Offline HARORIDER
« on: November 14, 2011, 09:28 PM »
been thinking about this for a while,if you say gyro whats good and whats not  :-\   :daumenhoch:
Re: GYRO OR NO GYRO THAT IS THE QUESTION ????
« Reply #1 on: November 14, 2011, 09:30 PM »
If you run a back brake, run a gyro.
You can't go wrong with an Odyssey GTX (or GTXR)
2 cables are better than one.
Offline Betty
« Reply #2 on: November 14, 2011, 09:35 PM »
Barspins or whips?
If no then no gyro
A straight cable's easier to set up and less hassle
2 minutes turkish...
« Reply #3 on: November 14, 2011, 09:35 PM »
I ran a gyro from the early 80s when they came out but a few years ago I switched to a straight cable (mainly cos the frame I got didnt come with mounts, it was right before removable tabs). It was OK and looked nice and clean, but my current bike came with tabs and im back with a gyro. Its great, love it. Less cable stretch, no cable flapping around AND i dont have to unwind the bars on the rare time that I spin them.
I chose the Oddy unit that has the built in pinch bolts so I could shorten the upper cable, with oddy twin cables/ lever.
Offline HARORIDER
« Reply #4 on: November 16, 2011, 06:16 PM »
what lever do you use alex? as i still like rear brake/left lever  :-\   :daumenhoch:
« Reply #5 on: November 16, 2011, 06:33 PM »
I use a Dragonfly Gemini upper gyro cable, and a regular Tech 99 (I think?) lever.
The D.G. is cut to length, and connected to my GTX-R gyro (fruity name, but great bit of kit - with the pinch bolts)
« Reply #6 on: November 16, 2011, 09:47 PM »
I use an Oddy M2 twin cable lever. It only comes in "right" but it works on either side
http://www.odysseybmx.com/catalog/braking/m2-lever/
renegaderacer
« Reply #7 on: November 17, 2011, 09:08 AM »
I always run a gyro and a well set up one will still lock the back brake at will with one finger. I went for the Snafu Mobeus as it had good reviews, it's easy to set-up, looks good and is about a third the price of an Odyssey GTXR. I run Blank cables (good colour choice) and a left hand eclat Swift lever.
« Reply #8 on: November 17, 2011, 09:50 AM »
Mine's much the same as Alex's - GTX-R gyro, medium monolever with the duel cable deal. Works a treat.
