0 Members and 12 Guests are viewing this topic.
might be worth considering toptube length at some point......
I take it these are second hand completes for £140?
I reckon you will get a decent used complete for 140, it will ride pretty much the same as a 1000 quid rig.
Your forks don't have lugs and more than likely the stem cap won't have a hole to pass the cable through It might have a hole in the forks for a caliper brake, some completes come with a caliper brake on the frontDon't put the forks off your mongoose on it, they'll probably weigh more than the whole bikeTyres are fine for park use...
Quote from: Betty on November 09, 2011, 11:07 PMYour forks don't have lugs and more than likely the stem cap won't have a hole to pass the cable through It might have a hole in the forks for a caliper brake, some completes come with a caliper brake on the frontDon't put the forks off your mongoose on it, they'll probably weigh more than the whole bikeTyres are fine for park use... I was only talking about nicking the front calipers, not the fork - might be cromo but there's a lot of itat the very least I might need to swap the lever over as I think it's on the wrong (right) side for me
As others have said Griff the rear u brake will work a treat so you don't need a frontLugged forks are the way to go if you find you want one...
