975836 Posts in 138948 Topics by 6379 Members - Latest Member: McChippy72 January 11, 2025, 04:57 AM
RADBMX.CO.UK  |  BMX General  |  BMX Chat  |  chainring advice-help..
Author Topic: chainring advice-help..  (Read 353 times)
Offline dubber
« on: October 23, 2011, 05:43 PM »
im after changing my 39t chainring to hopefully something smaller even a small amount would be good as it looks like a dinner plate.. :LolLolLolLol:
im sure the rear freewheel is 14t so what the smallest i can put on there without changing the freewheel..
i suppose even if i was able to change whats there now would be good enough for the moment...links would be great help if you can..looking to make a straight swap if possible...
this is the one i want to change..
lastly can i use a half link chain on this bike? dont want to spend 30 odd quid and it doesnt work..
thanks for your time chaps...Paul.. :daumenhoch:
Offline Dannywhac
  • return of the whac
Re: chainring advice-help..
« Reply #1 on: October 23, 2011, 06:32 PM »
To be honest fella, 39's the smallest you can go and not lose speed/acceleration. You could prolly drop to a 36 although it'd be soft as hell.
Have a look at the chart here:
2.75's the ideal ration, higher and harder to pedal but more speed, lower easier to pedal but low top speed.
HEYWOOD BMX
« Reply #2 on: October 23, 2011, 06:38 PM »
 :) 38/14 should be an OK gearing.A half-link chain (1/8 size) should also work fine.I`ve used Gusset Slink chains (cost under £20) for ages with no probs...
