975808 Posts in 138943 Topics by 6370 Members - Latest Member: Robertflamn November 26, 2024, 06:24 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Spoke Length Z rims to Suzue low flange
Author Topic: Spoke Length Z rims to Suzue low flange  (Read 861 times)
« on: October 22, 2011, 12:00 PM »
I am about to embark on a wheel build for Dan but am not a 100% on spoke length for a lace 4.  I would say 194mm with long nipple as per building a set of 7x's will that be a good length
Thanks in advance :daumenhoch:
Brett
Offline steve69
  • aka. Steve Changa
Re: Spoke Length Z rims to Suzue low flange
« Reply #1 on: October 22, 2011, 01:33 PM »
I'm thinking 188's   :-\
i've not done 4x, but the 3x, z-rim to low flange i done a while ago was 184's with long nipples.
« Reply #2 on: October 22, 2011, 01:42 PM »
Quote from: Londonhellboy
Always use 194mm for low flange hubs with a X3 pattern. 184 - 186mm for High flange hubs with a X3 pattern
If you want to use a X4 pattern, you will need around 196mm dude but you can stretch them easily if you have 15mm nipples
Offline steve69
  • aka. Steve Changa
« Reply #3 on: October 22, 2011, 02:13 PM »
I would agree if you were lacing Araya 7X style rims, but a Z-rim has a raised centre so you will need shorter spokes.
I've got a log of rim/hub/nipple/spokes sizes and lengths that i've been keeping as i have been building wheels and as said i've not built that combo yet so i can't say for sure.
I have built...
z-rim/lf 3x=181's,
z-rim/sf 3x=184's,
z-rim/bullseye 3x=184's,
z-rim/phil wood 3x=184's,
7x/lf 3x=184's,
7x/sf 4x=194's,
7x/bullseye 4x=194's,
20x1-3/8"/lf 2x=194's
So i think 196's will be way too long :-\
