975810 Posts in 138943 Topics by 6371 Members - Latest Member: Robertflamn November 28, 2024, 03:51 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  dyeing a seat
Author Topic: dyeing a seat  (Read 1295 times)
oldskooldayz
dyeing a seat
« on: October 18, 2011, 12:32 AM »
If i dye a yellow seat blue i imagine it will turn green, can anyone confirm this or will it turn blue ?
Re: dyeing a seat
« Reply #1 on: October 18, 2011, 01:05 AM »
yes it will turn green  ;)
 :shocked:but
it will be a dirty green like army green
when making a nice bright green, it's yellow with a touch of blue - but when adding blue onto a yellow seat it might just turn blue but it will not be a kashi blue as far as i can work out and know - it is more than likey to make it into a sea green / army green
it's hard to say but if the seat is worth money then i would just dye it yellow and sell it and put the money towards the right colour seat
this is just my thoughts - so see what others say
cheers B
oldskooldayz
Re: dyeing a seat
« Reply #2 on: October 18, 2011, 01:12 AM »
I think you spot on mate and i thought it would turn green anyway but just wanted to check
the seat is a cheap one anyway but thought it was worth asking as i cant seem to get a blue seat at the mo  :LolLolLolLol:
thanks for the reply  :daumenhoch:
Offline Discostu
  • Two's Company
Re: dyeing a seat
« Reply #3 on: October 18, 2011, 08:49 AM »
Why don't you buy a repop dominator seat in blue from pork chop. They are reasonably cheap and are exactly the same as the original. Just stamped with a current date. I take it that you want it for your Haro retro so I can't see the problem with fitting a repop. If it was ment to be era correct it might be a bit different. Hope this helps stu :daumenhoch:
Re: dyeing a seat
« Reply #4 on: October 18, 2011, 09:18 AM »
ive just dyed a yellow tuff red and it turned out red, it should dye blue because your not mixing the colours
Re: dyeing a seat
« Reply #5 on: October 18, 2011, 11:47 AM »
up to you if you want to try it ?
can you loose the seat if it doesn't work ?
oldskooldayz
Re: dyeing a seat
« Reply #6 on: October 18, 2011, 02:10 PM »
I could buy a seat from pork chop but easier to buy of a member who may need some dosh but I may fo that route
As for the wheel that turned out well sweet  :daumenhoch:
I only paid 14 quid for the seat an it's only a copy thing so yep can loose it if it mucks up
Thanks for the replies peeps  :daumenhoch:
Threaders
Re: dyeing a seat
« Reply #7 on: October 18, 2011, 05:37 PM »
Bear in mind, if you sit on it, the dye will rub off on your pants, and you will end up with yellow showing back through on the seat.  ;)
oldskooldayz
Re: dyeing a seat
« Reply #8 on: October 18, 2011, 06:14 PM »
and a blue bum  :LolLolLolLol:  :daumenhoch:
Offline rick1970
Re: dyeing a seat
« Reply #9 on: October 18, 2011, 10:50 PM »
Or stick one of those blue checker cover thingies on it till something pops up  :D
