Don`t like the shorter headtube-fork steerers are already stupidly short with no room for height adjustment
Would you be able to fit a gyro or is it designed for "normal" rear bake set up
Looks OK.KisBikeCo already have forks out with the same dropouts.
Yeah, it will be a twitchy frame.
Quote from: S&MAlex on October 13, 2011, 04:12 PMYeah, it will be a twitchy frame.Thats my mind made up Back to the drawing board
38 Special Pete, a do everything bike, Track, trails and park. They are not twitchy in the slightest. Failing that Deluxe with a v brake, same gig, do everything bike
Kev, you need to remember the WTF and dirt bike have very different geometry so it would probably take some getting used to if you went for one.WTF = 75.5 HT angleWTF = 11.4 BB heightDirtBike = 74.5 HT angleDirtbike = 11.8 BB height.I think the WTF would be twitchy as hell with that head tube angle. Thats probably why the BB has been lowered, to compensate for that. I like the closed dropouts and the idea of a stiffer front end (not that its needed unless it prone to flex due to thin tubing) on the WTF but not the geometry.
Peter - to be honest mate, just buy anything you fancy and get riding. You've little to compare to, so don't worry about it!You'll chop and change a bit as your riding progresses and then you'll be able to make an informed decision. Pretty much what we all did.All that said though - the Bonedeth Creepozoid that Glen suggested is damn near perfect mate. It's right shape and size for a grown up and it has no surprises in it's geometry or design. Can't go wrong really. And you know it's designed to go fast......
