975809 Posts in 138943 Topics by 6371 Members - Latest Member: Robertflamn November 27, 2024, 09:53 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  seat post stuck in the frame tube
Author Topic: seat post stuck in the frame tube  (Read 1151 times)
dj-paul-c
« on: October 09, 2011, 11:53 PM »
how easy would it be to get seat post out if its stuck inside the frame tube ?
the post is about 1.5--2" down from the top of the seat tube so wouldnt be able to get grips on it
any ideas how to get it out ??
cheers
Re: seat post stuck in the frame tube
« Reply #1 on: October 09, 2011, 11:57 PM »
What is it made of.  Aluminium or chromoly?
« Reply #2 on: October 10, 2011, 12:00 AM »
animal steve melted one out my GT pro with caustic.
« Reply #3 on: October 10, 2011, 12:05 AM »
it need to be an ally post to do that.  :daumenhoch:
If it chromoly WD40 and a patience or a Big drill :wtf:
Offline hotdog
« Reply #4 on: October 10, 2011, 08:32 AM »
It took me about 2 hours to put 3 cuts through a chro-mo seat post that was wedged in a good 4" into the seat tube. I used a hacksaw blade that I'd slotted into a piece of 3/4" x 7" dowel,for extra purchase. A lot of work/patience but my only option once I'd been down the vice/lubricant/heat gun route.
super mat
« Reply #5 on: October 13, 2011, 09:29 PM »
i removed a mk1 burner post by first of all soaking in plus gas down the seat tube(also thriugh the bb if you can access it).i then drilled a 10mm hole through the post .i then inserted a bar through the hole so that there was no play.i then give the post a few taps from the top with hammer and then used the bar to turn the post out.i think i read this somewhere on here.this might not work all the time but it certainly worked for me.no caustic nor heat required.
Offline Spartacus
« Reply #6 on: October 13, 2011, 09:59 PM »
Use a slide hammer.
