975805 Posts in 138943 Topics by 6363 Members - Latest Member: V6 DOW November 23, 2024, 10:37 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  1985 Haro Master paint advice
Author Topic: 1985 Haro Master paint advice  (Read 5342 times)
Re: 1985 Haro Master paint advice
« Reply #25 on: October 05, 2011, 01:27 PM »
I'm feeling a deja vous moment, didn't this question get asked in a post before?
Yep but I didn't want to rub it down and paint over it, that was the result before, thought i'd post it again when I was getting around to building it which is about now  :coolsmiley:
« Reply #26 on: October 05, 2011, 01:27 PM »
got some tippex you can borrow matt - would work on the chips AND yellow bits
just PM me your details  :daumenhoch:
LOL  :D ;)
« Reply #27 on: October 06, 2011, 08:29 AM »
Offline JAY
« Reply #28 on: October 14, 2011, 09:55 AM »
Matt, you have have to have a lot of patience when doing this, i would use wet n dry to take off the yellow, you just have to take it down slowly and not go through the original paint. Touching it in again is a patience thing, i build the paint up in layers, letting it dry each time and then flatten it off with a wet n dry,(again,be careful not to rub it down too much) then bring it up with t cut and it should blend in spot on. Think i told you before to get Domestic white colour as it matches the original paint pretty much perfect.
ukoldschool
« Reply #29 on: October 14, 2011, 10:45 AM »
'appliance white' from halfrauds is a good match from memory
« Reply #30 on: October 14, 2011, 10:48 AM »
Thanks Jay  :daumenhoch:
