975798
Bmxflex
November 16, 2024, 09:16 PM
New School BMX 2004 - Now
Removeable giro tab holes in frames
Topic: Removeable giro tab holes in frames (Read 1800 times)
oldtired
540 Air
Dirty Old Man
September 27, 2011, 11:35 PM »
are they all set at the same hight on new schoolie frames? if so? any chance of one of you bunging up the measurment from top of the headtube to center of top hole/mounting position?
fugazi
Site Supporter
540 Air
Re: Removeable giro tab holes in frames
September 28, 2011, 09:15 AM »
Are You going to use the usual generic type or the Fly Guiri tabs?
oldtired
540 Air
Dirty Old Man
September 28, 2011, 10:38 AM »
hadn't decided as yet which is one of the reasons i was asking as i know they are different , although it looks like its only aboout 5mm diference between the two sets of tabs, quit like the look of the fly ones with the thread in the middle instead of the generic L shape tab , i assume you've got new schoolie frame , measurements would be cool for which ever tabs you use
Last Edit: October 04, 2011, 07:49 PM by oldtired
fugazi
Site Supporter
540 Air
September 28, 2011, 01:37 PM »
I've got both types here, I'll measure them & get back to You
oldtired
540 Air
Dirty Old Man
September 28, 2011, 03:28 PM »
nice one
do you think drilling holes in a frame voids your warranty then ?
fugazi
Site Supporter
540 Air
September 28, 2011, 04:02 PM »
Personally I don't think it should if it's done well, but most bike co's will say it does! Here's the measurements from Two frames I have
Frame with Fly tabs 15mm to centre of top threaded hole.
Frame with normal tabs 22mm to centre of peg hole.
oldtired
540 Air
Dirty Old Man
September 28, 2011, 04:51 PM »
cheers for that
figured it was about 5mm difference so with it being 7mm wouldn't of been that far out , right, a little bit of fiddling then
Last Edit: September 28, 2011, 09:35 PM by oldtired
fugazi
Site Supporter
540 Air
September 29, 2011, 09:38 AM »
I'd think You could go a few mm either side of those measurements with no problems anyway, main thing is to get them level both sides
JAY
Site Supporter
Cherry Picker
November 11, 2011, 10:28 PM »
Does anyone know the thread size for the Giro tabs
Peter J
BMX Nerd
I have issues
November 11, 2011, 10:36 PM »
http://www.bmx-u.com/index.php'title=Adding_Gyro_Tabs
I might actually build a bike this year instead of just hoarding parts
JAY
Site Supporter
Cherry Picker
November 13, 2011, 10:54 PM »
Perfect, Cheers mate
