975822
Boults
December 26, 2024, 04:03 AM
BMX General
BMX Chat
SURELY
Topic: SURELY (Read 362 times)
WARDY
Double Flip Whip
SURELY
September 26, 2011, 04:54 PM »
Its just a mint pro neck with the bolt put in upside down , dont look right
http://www.ebay.com/itm/Pro-Neck-Inverted-stem-bmx-Jmc-Cw-Vdc-Redline-GT-/110748026747?pt=Cycling_Parts_Accessories&hash=item19c918c77b
Munnyella
Look Back
Re: SURELY
September 26, 2011, 05:03 PM »
I don't know, but the first ripper I ever saw had a black one of these on it just the same, that was about `82.
Was told that it was a cruiser stem, but there will be more opinion along shortly i'm sure.
MM
diesel
Look Back
Re: SURELY
unfortunately you can't just swap the bolt over like that.....
$200 is cheap so far
Swivel
Berm Worm
Ah feck it, go on then...
Re: SURELY
September 26, 2011, 05:19 PM »
Doesn't look like its aligning correctly?
markyp
900 Air
Re: SURELY
September 26, 2011, 05:26 PM »
on the inverted pro necks the stamping goes on the top,not on what is the cap on an ordinary one.the one on ebay has the stamping on the cap,it should be on what is now the top(what should be the bottom usually) basically the long top part should have the stamp,not upside down on the cap,someones just fudged that one together
glenboy
540 Air
Re: SURELY
September 26, 2011, 08:02 PM »
not contradicting markyp but to my knowledge which isn't great that pro neck is right i had a nos gold one and that was the same in the packaging , the tuf neck ones are stamped on the long top part but the 2 other ones of the inverted pro necks i have seen were stamped on the top bit (the cap) which is now underneath on the inverted ones if you know what i mean , i'll see if i can find some pics , as marky says i'm sure you could flip it over but the real ones are like that
and a tuf neck one which marky rightly says has the stamping on the now top bit
Last Edit: September 26, 2011, 08:14 PM by glenboy
BMX General
BMX Chat
SURELY
