975806 Posts in 138943 Topics by 6363 Members - Latest Member: V6 DOW November 24, 2024, 11:09 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  ACS Z Rim Resto help needed
Author Topic: ACS Z Rim Resto help needed  (Read 9594 times)
Re: ACS Z Rim Resto help needed
« Reply #25 on: September 11, 2011, 03:49 PM »
rip z rim :'(
i'd have a go at fixing that..not to be ridden on though...ill have them if your going to chuck them
« Reply #26 on: September 11, 2011, 03:51 PM »
that zds had it mate  :'(  and as the ruler says u should have taken the free wheel of before you cut the spokes .....
Offline Peter J
  • I have issues
« Reply #27 on: September 11, 2011, 03:59 PM »
If you try and straighten that front hub you'll run the risk of fracturing or stressing the metal unless you relief the metal first with heat.....but it takes practice doing it on thin alloy
And that sprocket is going to be a sod to remove on a high flange Hub.................unless you have the tools  :coolsmiley:
If you want a hand LMK  :daumenhoch:
oldskooldayz
« Reply #28 on: September 11, 2011, 04:03 PM »
Truly gutted about the rim being split and i would love to fix it but i will just keep my eyes open for a spare one
as for the freewheel i will get it off as a mate of mine has a handy little vice type clamp and has done it before
i was just being mega lazy as usual
how much does a split z rim sell for then  :LolLolLolLol:
« Reply #29 on: September 11, 2011, 04:06 PM »
A freewheel remover is a great purchase, and they are very cheap.
First you will need to build the hub into a wheel though. Thankfully it's a high flange hub and you can get the spokes past the freewheel though.
Don't have to go nuts getting all the spokes tight though, a slack build will do to hold the hub still while you wind of the freewheel.
If you dont have a freewheel tool, and the freewheel is expendable, just crush it in a vice and turn the hub off it.
Still need to build up the wheel though!
The hubs are soft, so vicing the hub could squish it.
oldskooldayz
« Reply #30 on: September 11, 2011, 04:13 PM »
as they are acs hubs i will get it dont right as said above  ::)
not worth fooking up when they can be saved
sid1972
« Reply #31 on: September 11, 2011, 05:08 PM »
oldskooldayz
« Reply #32 on: September 11, 2011, 05:53 PM »
exactly  :'(
need to find another one now
Offline rick1970
« Reply #33 on: September 11, 2011, 06:20 PM »
Gutted for yer mate  :(  thats the sort of thing that would happen to me not a good day is it for wheel resto them white skys too  :tickedoff:
« Reply #34 on: September 11, 2011, 06:26 PM »
It's luck that it has showed up now and not after they have been rebuilt and ready to go on a bike
well have a check of the other one and see what that is like
sorry for you mate and it's a shame - put up a wanted add and see if any one has a single one
oldskooldayz
« Reply #35 on: September 11, 2011, 07:29 PM »
Wanted add is up and waiting
i think it was hidden when it was laced up and tight and when i looked over them originally they just looked like they had a few deep scrapes
also as z rims are made with 3 joins i also thought at first it was one of the joins untill they came out of the dish washer then  :shocked: :'( :tickedoff:
fingers crossed another will appear
the rear is sweet as so at least i have one and 2 large flange acs hubs
