975811 Posts in 138943 Topics by 6371 Members - Latest Member: Robertflamn November 29, 2024, 07:33 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  losing the bling
Author Topic: losing the bling  (Read 1950 times)
losing the bling
« on: September 01, 2011, 05:50 PM »
i bought a nice shape badly faded square corner pat pending tuf neck stem from the museum,i was hoping that when it arrived it was good enough condition to just de-ano and leave as is to maintain the brushed og finish,unfortunately when it landed it wasnt as good as i thought so out came the wet and dry and its now a polished stem. what i want to know is how do you return it back to a brushed finish? im trying to go with as many og finishes as possible on my last build and a brushed stem is a must,so whats the answer ::)
Offline Dannywhac
  • return of the whac
Re: losing the bling
« Reply #1 on: September 01, 2011, 05:53 PM »
Think you can re-create the finish using a whetstone :)
« Reply #2 on: September 01, 2011, 05:55 PM »
whats one of them?i live by a beach, is that a pebble thats just come out of the sea? ;D
baldbmxer
« Reply #3 on: September 01, 2011, 05:56 PM »
SteveP is your man for this. He has the whole process down  :daumenhoch:
Check to see if theres a sticky on this somewhere, there was a thread on how he did it. The results were amazing
Offline Dannywhac
« Reply #4 on: September 01, 2011, 05:57 PM »
Not as popular anymore since people stopped using sythes  :D
Think I remember reading a thread somewhere here that SteveP recreates the 'brushed' alu finish with a whetstone - maybe pop him a pm? :)
And beaten to it again ;)
Offline kuwahero
    • Western Titans
« Reply #5 on: September 01, 2011, 06:02 PM »
Whetstone, a sharpening stone used for knives and other cutting tools. I have used one for this too and it works brill :daumenhoch:
Offline rooski
  • Mons Veneris
« Reply #6 on: September 01, 2011, 07:51 PM »
just wrap some emerycloth round a file,grab each end and draw it to and fro over the stem making linear strokes :daumenhoch:
Tuf necks would have originally been finished using a Linsher,which is basically a belt sander mounted on a pedestal :daumenhoch:
the parts were simply pushed onto the moving belt by hand making the familiar brushed finish :daumenhoch:
A typical linisher is shown below :D
« Reply #7 on: September 01, 2011, 08:13 PM »
cheers rooski,i think i have one of those linishers kicking about the house somewhere ;D
Offline rooski
  • Mons Veneris
« Reply #8 on: September 01, 2011, 08:17 PM »
Doesn,t everyone have one ??? :D
deeman
« Reply #9 on: September 01, 2011, 09:57 PM »
to replicate this finish,you should be able to get a bit of 80 grit wet n dry or maybe try softer to start with like a 180 grit and rub the part one way in a linear motion(to replicate the belt sander,then clean it up with first a red(coarse)scotch brite,then a grey(fine)scotch.you can stop at any stage when you think it looks right.i work with alloy wheels and have to try and replicate many different finishes,this should work.try a test area maybe underneath to start with first.
« Reply #10 on: September 03, 2011, 12:21 AM »
Mark ,
Search for some of Steve P's threads first ! , learn before you fook it up even more  :LolLolLolLol:
You ditching the shiny bling & flip flops ? ......  :D
« Reply #11 on: September 03, 2011, 08:04 AM »
parcy, you will fook it up trying it yourself, especially if you have never done it before and especially if you use 80grit, that will leave deep grooves, send it to paul at CCA and he can replicate this finish to perfection and it also gets anodiced silver as original finish so will never tarnish with age....    ;)
« Reply #12 on: September 03, 2011, 12:03 PM »
Mark ,
the flipper flops are standard issue clothing down on the south coast :D
« Reply #13 on: September 03, 2011, 12:28 PM »
« Reply #14 on: September 03, 2011, 02:54 PM »
