975755 Posts in 138933 Topics by 6360 Members - Latest Member: TattooedYorkie September 22, 2024, 12:41 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  MX 900 and GT
Author Topic: MX 900 and GT  (Read 943 times)
Offline Andy68
MX 900 and GT
« on: September 01, 2011, 10:14 AM »
Will the reach of the rear MX900 be long enough on the GT pro frame before I splash out? Ta
Re: MX 900 and GT
« Reply #1 on: September 01, 2011, 12:05 PM »
Not sure Andy but an MX900 is 90mm from the centre of the bolt perpendicular to the furthest reach of the brake block bolts, an MX1000 is 100mm, an 890 is 89mm, a 1020 is 102mm and a 1080 is 108mm.....
Put the wheel in the frame, put a bit of tape on the rear stays where the rim reaches, take the wheel out, put a straight edge accross the two tape marks and measure up to the the spindle bolt hole to see which size you need :daumenhoch:
That's about the only way to have a guess, unless someone has a GT with MX900's on of course :coolsmiley:
Spen
Rodgy1970
Re: MX 900 and GT
« Reply #2 on: September 01, 2011, 12:17 PM »
An MX 900 is the correct length for a GT pro IMO, here's a mock up I did
