975811 Posts in 138943 Topics by 6371 Members - Latest Member: Robertflamn November 28, 2024, 10:17 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  TPI On Profile Racing Cranks
Author Topic: TPI On Profile Racing Cranks  (Read 771 times)
Offline Dannywhac
  • return of the whac
« on: August 26, 2011, 03:35 PM »
Hi all - anyone know the TPI for Profile Racing cranks - got an axle that the threads are a little bit damaged (fixable though without drilling larger) and need to get a tap to do the job - ta in advance  :daumenhoch:
Offline kuwahero
    • Western Titans
Re: TPI On Profile Racing Cranks
« Reply #1 on: August 26, 2011, 03:40 PM »
They are 3/8 X 24 UNF have done this myself in the past :daumenhoch:
Offline Dannywhac
« Reply #2 on: August 26, 2011, 03:47 PM »
Cheers fella  :4_17_5:
Offline Peter J
  • I have issues
Offline kuwahero
    • Western Titans
« Reply #4 on: August 26, 2011, 03:53 PM »
I still have tap set from when I did mine if you want me to try fixing it. :daumenhoch:
Offline Dannywhac
« Reply #5 on: August 26, 2011, 03:56 PM »
Cheers fella - just need the tap as I've got another axle needs doing, so might as well buy the tap  :daumenhoch:
Offline john4130
« Reply #6 on: August 26, 2011, 05:06 PM »
i thought the profile axle was a 3/8" 26tpi. i remember snapping a bolt years ago and using a piece of a wheel axle with a nut on it to replace it. suppose it could have been a 24 tpi axle tho. they were the same thread as the old g sport hub bolts too.
