975806 Posts in 138943 Topics by 6363 Members - Latest Member: V6 DOW November 24, 2024, 11:04 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Oxy / Vinegar Bath !!! Pics now Added !!!
Author Topic: Oxy / Vinegar Bath !!! Pics now Added !!!  (Read 4922 times)
Offline tobytyke
« on: August 24, 2011, 10:26 PM »
My latest project turned up today
Might need a little more work than anticipated to remove the rust
I am reluctant tbh to get it Re-chromed as I've heard it can be abit hit & miss
& could obviously be costly if the finish is not the best
If all else fails it will get powdered along with the bars
What is the crack with these Oxy / Vinegar baths
Also coke, foil, etc etc ??  :-\
Cheers..., Lee  ;)
« Last Edit: August 26, 2011, 05:33 PM by tobytyke »
Re: Oxy / Vinegar Bath !!!
« Reply #1 on: August 24, 2011, 11:03 PM »
An oxy bath will eat away at the rust and leave a bare metal finish, it doesn't damage/affect the chrome at all.
Offline tobytyke
« Reply #2 on: August 24, 2011, 11:24 PM »
What will I need exactly ??? Water &  :LolLolLolLol: :LolLolLolLol:
Lee
Rodgy1970
« Reply #3 on: August 24, 2011, 11:32 PM »
Oxalic acid, citric acid or phosphoric acid all do the job and all available on ebay.
I've used oxalic acid and had some great results, as Stidds says removes the rust and not the chrome and will get into all the nooks and crannies which coke and tin foil doesn't and it's messy to use, vinegar works but it stinks.
Not tried citric acid or phosphoric acid yet.
I use it outside as it gives off fumes and wear gloves as it will really irritate your skin.
This was 25g per 100ml, I also had good results using 250g to 5l
« Reply #4 on: August 25, 2011, 11:05 AM »
got links to whast we should be looking for and buying please  :angel:
« Reply #5 on: August 25, 2011, 11:48 AM »
« Reply #6 on: August 25, 2011, 01:15 PM »
 :daumenhoch: nice one me old mucker  ;)
« Reply #7 on: August 25, 2011, 10:09 PM »
I use citric acid powder - mix with water - chuck in your bits - no nore rust  :daumenhoch:
I wouldn't use vinegar on survivor chrome - it can "pickle" it and you can end up with a kind of wishy washy "stain" effect if you are not careful.
Vinegar is OK for removing rust on bare metals or galvanised bits like seat guts and BB's and harware etc. but I wouldn't use it on chrome.
I just stick with the citric acid powder for everything now though  :daumenhoch:
Offline tobytyke
« Reply #8 on: August 25, 2011, 11:39 PM »
I need to try something without the wait for stuff off internet
Ive had a quick clean off it but it looks pitted
Wanted to try something quick, but I can't find anywhere that sells citric / oxalic
My feeling is its gonna get powdered, it looks too far gone  :(
Lee
Moza
« Reply #9 on: August 26, 2011, 11:30 AM »
Offline tobytyke
« Reply #10 on: August 26, 2011, 11:47 AM »
Where did you get the Citric from ?
I live in a pretty rural area
Moza
« Reply #11 on: August 26, 2011, 12:11 PM »
ebay :daumenhoch:
Offline tobytyke
« Reply #12 on: August 26, 2011, 12:30 PM »
No dramas, made a call to Home brew shop what stock it
Popping over there in while
Cheers.... Lee  ;)
Rodgy1970
« Reply #13 on: August 26, 2011, 12:38 PM »
Cheers.... Lee  ;)
before and after pics  :daumenhoch:
Offline tobytyke
« Reply #14 on: August 26, 2011, 12:58 PM »
Cheers.... Lee  ;)
Yeah will do no dramas  ;)
Offline tobytyke
Re: Oxy / Vinegar Bath !!! Pics now Added !!!
« Reply #15 on: August 26, 2011, 05:39 PM »
Ok, been & bought some Citric Acid earlier
Will give it a go but as I've said, think it may be too far gone
& will probably end up getting powdered
Anyway here are some Before shots
Will post up Pics of the results if anything happens
I used 25g Citric to 1lt Water
See how that goes
Fingers Crossed  :LolLolLolLol:
Lee  :)
hooga1975
« Reply #16 on: August 27, 2011, 09:56 AM »
I have a TA and the forks look just like yours.  I was thinking of selling it on but I would be interested to see how your comes out.  I am looking forward to see how this works
Offline tobytyke
« Reply #17 on: August 27, 2011, 11:36 AM »
Just had a check on the F & F, looks as if it's shifted abit
Maybe need more Citric, not sure  :-\
Oxalic may be better but again unsure
Think it's all far too gone TBH
Lee  :(
donkeybambam
« Reply #18 on: August 27, 2011, 11:44 AM »
ox acid will shift that but in my opinion them forks look like it has eaten through the chrome underneath and just got grown and grown.
Offline tobytyke
« Reply #19 on: August 27, 2011, 11:51 AM »
Yeah think your right
Wanted to give it a try as I would have liked to keep it as it is
But give it go & see what happens
The chrome has gone in afew places on the frame aswell
Eh ho, that's what you get with 30yr old kids bikes I suppose  :LolLolLolLol:
Lee  :D
Online oldschoolace
« Reply #20 on: August 27, 2011, 04:21 PM »
I would say they look a bit too far gone to be honest, even if you shift the rust there will be pitting underneath. Having said that sometimes you get a kind of scab of rust and the steel underneath comes up fine. With citric acid it helps if you scrub at the worst bits with a toothbrush every few hours if possible so the acid can do its stuff. I would say the ratio of powder to water you are using is ok if you give it time :daumenhoch:
Make sure the acid you are using is pure acid. Sometimes the stuff you get from brewery supllies shops have additives to help with the brewing, these dont help strip rust.
« Last Edit: August 27, 2011, 04:25 PM by oldschoolace »
Offline tobytyke
« Reply #21 on: August 27, 2011, 07:02 PM »
Nothing to report
I've had to remove from Citric bath as the wife wants her bathroom back  :LolLolLolLol: :LolLolLolLol:
As anticipated there is pitting to the chrome which is a shame
Some you win some you lose  :'(
I would have really liked to have done this Chrome & Blue as mine was BITD
I'm getting it powdered now as I'm not taking the chance of a dodgy re-chrome as well as the expense
Decision time now oncolour scheme  :-\
Lee
OSBMXLIVES
« Reply #22 on: August 27, 2011, 08:04 PM »
Nothing to report?
Let me help you out there;
It's rustier than a very rusty, rusty thing, from rusty'sville, Tennesey, and it WILL need blasting and powder coating. No amount of pricking about with 'condiment' will fix this piece of crap! There, did that help?
OH, that feels better!
Ad  :daumenhoch:
Offline tobytyke
« Reply #23 on: August 27, 2011, 09:09 PM »
Nothing to report?
Ad  :daumenhoch:
Oh I hear ya, but less of the Crap eh  :knuppel2:  :LolLolLolLol: :LolLolLolLol:
Lee  ;)
