975808 Posts in 138943 Topics by 6371 Members - Latest Member: Robertflamn November 27, 2024, 08:26 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Stem help !!
Author Topic: Stem help !!  (Read 2039 times)
Offline tobytyke
Stem help !!
« on: August 24, 2011, 05:20 PM »
My new build arrived today
The stem Allen bolt is fooked, rounded out & rusted to Fook
Need it off  as to get the forks off
Any tips  :-\
Lee  :idiot2:
Offline Peter J
  • I have issues
Re: Stem help !!
« Reply #1 on: August 24, 2011, 05:46 PM »
Drill (better if you know someone with a pillar drill)
A steady hand
and a rubber hammer  :daumenhoch:
Oh and WD40
Re: Stem help !!
« Reply #2 on: August 24, 2011, 05:53 PM »
If it protrudes from the stem, an external stud extractor would do the job.
Offline tobytyke
Re: Stem help !!
« Reply #3 on: August 24, 2011, 06:10 PM »
The bolt is not protruding
Just tried drilling with no impact what so ever
 :idiot2: :'( >:D  :2gunsfiring_v1: :2gunsfiring_v1:
Re: Stem help !!
« Reply #4 on: August 24, 2011, 06:50 PM »
Get a hold of some spline bits.
The one for VW driveshafts is just a fraction bigger than a 6mm allen key - you should be able to get this spline bit at a good car accessory shop.
Get this VW driveshaft spline bit, and hammer it into the the allen bolt.
Also before you do it,  pour a kettle of boiling water over it - the heat may help you out.
Re: Stem help !!
« Reply #5 on: August 24, 2011, 06:50 PM »
put up a picture of the offending bolt so we can see what we are dealing with.
Offline Peter J
  • I have issues
Re: Stem help !!
« Reply #6 on: August 24, 2011, 07:01 PM »
Offline tobytyke
Re: Stem help !!
« Reply #7 on: August 24, 2011, 07:12 PM »
Desperate times calls for desperate measures
Hack sawed the Cnut off  >:D
Wanted to keep the forks as now the remainder of the stem & wedge etc is stuck firm
Lee  ;)
Re: Stem help !!
« Reply #8 on: August 24, 2011, 07:15 PM »
So the bolt didn't protrude, but you managed to hacksaw it off?
Or - you hacksawed through the stem?????
Offline tobytyke
Re: Stem help !!
« Reply #9 on: August 24, 2011, 07:17 PM »
Through the stem, pics to follow
Re: Stem help !!
« Reply #10 on: August 24, 2011, 07:17 PM »
Bet that stem took some sawage!
Is there a bunch of stem junk stuck in the fork's steerer tube now?
Offline rooski
  • Mons Veneris
Re: Stem help !!
« Reply #11 on: August 24, 2011, 07:23 PM »
Gonna be hard to get the rest out now :(
Offline tobytyke
Re: Stem help !!
« Reply #12 on: August 24, 2011, 07:29 PM »
Cowboy  ;D ;D ;D
Bru  :daumenhoch:
:LolLolLolLol: :LolLolLolLol:
This is what I'm left with on the forks
If anyone knows or can get the remainder of the stem out for me
I would be eternally grateful
Would like to keep the forks original to the frame
Or should I just get another set
Lee  :D
Offline Peter J
  • I have issues
Re: Stem help !!
« Reply #13 on: August 24, 2011, 07:32 PM »
What stem was it ?
Re: Stem help !!
« Reply #14 on: August 24, 2011, 07:35 PM »
Hammer the shit out of it from underneath.
Be sure that the drift you use fits nicely in the steerer tube.
Maybe give it a tap at the top too, to break the seal.
I wish you had tried my spline tool method in the allen bolt. You could have used the stem itself to shift the shaft!
But you could start by whacking the bolt itself - maybe push the wedge bit down and free off the steerer tube.
Good luck . . . !
Offline tobytyke
Re: Stem help !!
« Reply #15 on: August 24, 2011, 07:36 PM »
Just some cheapo shoite thing
Re: Stem help !!
« Reply #16 on: August 24, 2011, 11:09 PM »
big hammer and smash it to fook  :daumenhoch:
Offline Peter J
  • I have issues
Re: Stem help !!
« Reply #17 on: August 24, 2011, 11:19 PM »
Or just let the Man Mountain Dordy  ::) growl at it and the fooker will fall apart  :shocked:
Re: Stem help !!
« Reply #18 on: August 24, 2011, 11:20 PM »
yes.
Offline tobytyke
Re: Stem help !!
« Reply #19 on: August 24, 2011, 11:27 PM »
General Concensus
Big Fookin Hammer Tomorrow  >:D  :LolLolLolLol: :LolLolLolLol:
Lee  :)
Rodgy1970
Re: Stem help !!
« Reply #20 on: August 24, 2011, 11:41 PM »
Wrap some insulating tape round the threads to protect them a bit.
Hammer the fook out of what's left of the stem wedge downwards, if it drops down drill a hole through the shaft, put a bolt in it, hold shaft in vice, bar through forks and turn.
