975806 Posts in 138943 Topics by 6363 Members - Latest Member: V6 DOW November 24, 2024, 06:26 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  campy axles
Author Topic: campy axles  (Read 913 times)
Offline wildon
campy axles
« on: August 17, 2011, 12:16 PM »
anyone know if i can get these in UK before i go and order them from US?  http://harriscyclery.net/itemdetails.cfm?ID=2250
Re: campy axles
« Reply #1 on: August 17, 2011, 01:49 PM »
Hard to find OG ones anywhere , I've found some before & they cost a fair bit more than the EAI ones but I've also bought EAI before and they're fine  ;)
steve
Re: campy axles
« Reply #2 on: August 17, 2011, 05:54 PM »
hello, you simply buy one of these
http://www.ebay.co.uk/itm/Axle-Front-Solid-M9-x-140mm-non-quick-release-/160547167405?pt=UK_sportsleisure_cycling_bikeparts_SR&hash=item25615b5cad
7 pounds ffs - they used to be 4 quid.
you run up one campy cone - the thread pitch is slightly different, push out the short quick release axle with the new-un - then fit t'other cone.
much cheaper even at 7 quid.
please note, yes you are being anal about liking the campy acorn nuts
Offline wildon
Re: campy axles
« Reply #3 on: August 18, 2011, 09:19 AM »
