975805 Posts in 138943 Topics by 6363 Members - Latest Member: V6 DOW November 24, 2024, 06:31 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Mongoose Bottom Bracket
Author Topic: Mongoose Bottom Bracket  (Read 1455 times)
Offline johnjo74
« on: August 17, 2011, 09:26 AM »
Can anyone tell me if I'm missing anything from this B/B set ?
I've another B/B that appears to be the same , apart from the non-drive side Mongoose stamped bit .........
....... is one an earlier version of the other ,  or fitted to to different models .
Thanks in advance  8)
« Last Edit: August 17, 2011, 09:41 AM by johnjo74 »
Offline 58 delray
Re: Mongoose Bottom Bracket
« Reply #1 on: August 17, 2011, 10:13 AM »
not that i can see  :daumenhoch:
Offline johnjo74
« Reply #2 on: August 17, 2011, 10:52 AM »
Cheers guys , was thinking maybe a spacer or something  8)
I'm pretty sure they are both for a OPC , the slotted one came from an '83 Cali .
The other bb is exactly the same other than it has the integrated nut ...thought one maybe an earlier version or something    ???
« Reply #3 on: August 17, 2011, 01:05 PM »
John. my brother needs a 28tpi opc BB so if you only need one, give me a buzz mate >:D
Had both sorts fella, the Mongoose stamped one with the integral nut is the easier to adjust so use that one first :daumenhoch:
Offline johnjo74
« Reply #4 on: August 17, 2011, 10:32 PM »
Cheers Spen  8)
I was going to put the other Mongoose BB in the 'For Sale' eventually  , but if you want it ,
 you can have it for twice what I was going to sell it for  :daumenhoch:  ;D
« Reply #5 on: August 17, 2011, 10:53 PM »
Ace John, I'll bring a fiver then ;-)
Offline johnjo74
« Reply #6 on: August 17, 2011, 11:00 PM »
 ;D
Offline oldtired
  • Dirty Old Man
« Reply #7 on: August 17, 2011, 11:24 PM »
missing a large washer that fits behind drive side cone ?
