0 Members and 6 Guests are viewing this topic.
the oven pride should be fine on the chrome,best thing to do is keep a bucket of cold water handy,that way you can clean the pedal off at intervals so that you can check the chrome and how the anno is doing.the time scale can vary for removing the anno,i did a tuf neck stem the other day and it was literally seconds wheras last night i did a chian ring and it took about 10 mins.make sure you finish off rinsing in cold water,any black 'burn' marks will scrub off if caught quick enough otherwise the wet and dry will tackle it
see,easy peasy,now for the ball ache of polishing
Quote from: markyp on August 13, 2011, 02:47 PMsee,easy peasy,now for the ball ache of polishing
cheers all came off a treat
