975833 Posts in 138948 Topics by 6376 Members - Latest Member: The Carrot Cruncher January 08, 2025, 11:55 AM
RADBMX.CO.UK  |  BMX General  |  BMX Chat  |  mig welding vs brazing?
Author Topic: mig welding vs brazing?  (Read 528 times)
« on: August 11, 2011, 02:22 AM »
Ok, go easy on me as i know fook all about either.
Lets just say i decided to chop shop a cheap steel frame and cut new tubes to a nice tidy joint. Could i fillet braze the joints with map gas and brass/silver rods or would a mig welder be better?
P.S I'm a cheap bstard and am only having a go so i dont want to spend hundreds on the right gear  :-[
Offline Peter J
  • I have issues
Re: mig welding vs brazing?
« Reply #1 on: August 11, 2011, 07:41 AM »
Both are good methods but............................its all down to the skill of the welder
Welding is a skill or even an art and its a bloody hard one to get right  :daumenhoch:
« Reply #2 on: August 11, 2011, 09:19 PM »
Braizing is stronger if done correctly as it does not melt the parent metal so doesn't build in added stress that needs 2 b anealed  ;) MIG is nice and strong but not as neat as TIG on thin tubing  :daumenhoch:
lk_97
« Reply #3 on: August 11, 2011, 09:42 PM »
So what exactly is a bubblegum weld? I've saw one but I don't really know what they are...
Offline Peter J
  • I have issues
« Reply #4 on: August 11, 2011, 09:44 PM »
Crap welding
http://www.jalopyjournal.com/forum/showthread.php?p=2748674
« Reply #5 on: August 11, 2011, 09:54 PM »
i'm thinking more brazing at the moment, looking to have a go making my own frame over the christmas hols.  :Great_Britain:  :daumenhoch:
Anyone got any tips?
Offline mattfx81
« Reply #6 on: August 11, 2011, 10:30 PM »
Brazing will be cheaper and more practical, mig isnt so good on thinner gauge materials. With brazing its all about the gap or rather creating the right conditions for the filler material to flow into the joint via surface tension to create a strong joint. Tig is even better as you have more control of the heat input in the joint and amout of filler material deposited but a  decent machine is expensive and requires practice.
« Reply #7 on: August 12, 2011, 01:23 AM »
Cheers. If i was looking to fillet braze a joint (i think thats what they call it) where you use more of the rod, like a mig weld i guess, do i still use flux or is that mainly to help the brazing material to flow into snug joints such as lugs?
Offline mattfx81
« Reply #8 on: August 24, 2011, 01:49 AM »
Yes, you can use the flux to help wet the surface to let the braze flow more easily.
