975800 Posts in 138943 Topics by 6362 Members - Latest Member: Bmxflex November 19, 2024, 11:07 AM
RADBMX.CO.UK  |  BMX General  |  BMX Chat  |  Bullseye Axles - What are my options?
Author Topic: Bullseye Axles - What are my options?  (Read 437 times)
Offline brass monkey!
« on: August 02, 2011, 08:40 AM »
i blagged a pair of original early 80's BULLSEYE HUBS (£30 !), but they have no axles....
They have the bearings etc., so I only need a pair of axles, ... can I get a pair or retrofit axles that will fit???, other than the expensive Bullseye ones?
thanks for any help...
Matt
Re: Bullseye Axles - What are my options?
« Reply #1 on: August 02, 2011, 08:59 AM »
cheapskate ..............
 ;D
« Reply #2 on: August 02, 2011, 09:03 AM »
 ;D
 :laugh:
yeah, you know me.........  :P
« Reply #3 on: August 02, 2011, 10:28 AM »
what size holes ?
cheap fooker and lucky fooker  ;D
HEYWOOD BMX
« Reply #4 on: August 02, 2011, 01:51 PM »
 :)  Find the thread/diameter and you should be able to get allen-head ones from any nut/bolt supplier.Bullseye bolts also fit new school Odyssey Vandero 2 hubs-you can get 2 diff types  of replacement so why not try sourcing these?
  **SIZE IS 3/8 X 24TPI**
http://www.customriders.com/prodshow.asp?prodid=12749&cat=2&parent=1001&sid=3
« Last Edit: August 02, 2011, 02:02 PM by VOIVOD »
« Reply #5 on: August 02, 2011, 09:02 PM »
i'll check them out, thanks :)
Offline Darren Wood
« Reply #6 on: August 03, 2011, 11:18 AM »
Matt didnt the early ones just have a bolt going into them ? so no axles  ???
i may be wrong  :-[
WOODY
Offline 58 delray
« Reply #7 on: August 03, 2011, 11:26 AM »
i may be wrong  :-[
WOODY
early one's were bolt through like woody says (single bolt that went through the axle with a nut on one side)
later versions came with allen head bolts on both sides (these come in 2 sizes so be carefull as the smaller size is just meant for small riders and wont take a grown ups weight)
Offline kuwahero
    • Western Titans
« Reply #8 on: August 03, 2011, 08:55 PM »
As Andy says. Bullseye ad from 81'
« Reply #9 on: August 04, 2011, 08:54 PM »
thanks Guys
yeah they should have the bolt through as Woody says,.
thanks for the info and pics,
looks like a 'Homebase' job for some nice long bolts then?  ;)
