975808 Posts in 138943 Topics by 6371 Members - Latest Member: Robertflamn November 27, 2024, 04:36 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Help! Why does my bike do this????
Author Topic: Help! Why does my bike do this????  (Read 1356 times)
austin
« on: July 28, 2011, 08:04 PM »
When I'm riding my Streetbeat now and again as I pedal there's a click noise and the pedal drops like the chains come off or something?? Not sure if it's the crank or freewheel and it seems to happen mainly when I pedal hard from almost standstill. Any ideas guys or anyone else had the problem, would appreciate yr opinions?
Re: Help! Why does my bike do this????
« Reply #1 on: July 28, 2011, 08:09 PM »
sounds like the freewheel is missing a couple of teeth, or if your running a 3piece crank check its all tight
Offline rick1970
« Reply #2 on: July 28, 2011, 08:13 PM »
rear sprockets goosed mate  :daumenhoch:
motomagII
« Reply #3 on: July 28, 2011, 08:14 PM »
yep needs new freewheel for sure
« Reply #4 on: July 28, 2011, 08:15 PM »
you might have overtightened the crank if its one piece with looseball  :-\
take it apart and have a look at the bearing cage as it could be bent
Offline Betty
« Reply #5 on: July 28, 2011, 08:24 PM »
Freewheels fooked...  :(
2 minutes turkish...
austin
« Reply #6 on: July 28, 2011, 08:36 PM »
Cool, thanks guys, I've got a spare freewheel so I'll swap that over at the weekend. They easy enough to get off cos mine was on the wheel when I bought it?
Offline Betty
« Reply #7 on: July 28, 2011, 08:44 PM »
You'll probably need a freewheel tool, or take it to a bike shop who'll charge a couple of quid to take it off
austin
« Reply #8 on: July 28, 2011, 09:05 PM »
cool, will do, thanks
twit twoo
« Reply #9 on: July 28, 2011, 09:05 PM »
Grip the freewheel in a vice, tighten it up until the outer layer forces itself onto the inner section. dont tighten too much or youll damage the hub. test  the pressure by spinning the wheel, which will be sat in your viuce like a steering wheel. chances are, by the time it starts getting difficult to turn, IE before you fook your hub, it will have given up and spun off the hub. thn chuck it across the shed like a ninja. 10 points if you get it to stich into the wall.
Offline steve69
  • aka. Steve Changa
« Reply #10 on: July 28, 2011, 09:55 PM »
You bought the wrong bike  :yahoo_silent:
« Reply #11 on: July 28, 2011, 10:23 PM »
hearings fooked - are there voices as well that you are hearing ?
freewheel and or bb crunching  ::)
freewheels can bite back, if they are on the verge of giving up  ::)
twit twoo
« Reply #12 on: July 28, 2011, 10:25 PM »
just missing a few crumbs of gravel in that.
« Reply #13 on: July 29, 2011, 12:36 AM »
been there  ;D
play hard till it hurts  >:D
Offline MaD-RoK
« Reply #14 on: July 29, 2011, 09:29 AM »
THought i opened a fookin halloween thread there...... Get stablizers back on bendy. :2funny: :2funny: :2funny:
« Reply #15 on: July 29, 2011, 09:38 AM »
